Failed Emissions
Ogden, Utah
Here in Utah some of us have to do a safety and emissions test and this year my cruiser FAILED!:bang: It failed in the Co readings, and I have done nothing to the emissions parts in the past year. My tech said it may be the o2 sensors. My question is....
1. Can I check my o2 sensors and how?
2. Are there any other possible links to failing the CO test.
(It is reading high)
3. I did replace my MAF sensor with a rebuilt one, could it be a
result of it not being properly set to spec? There is a rich and
lean adjustment screw on the side, is that a possible adjustment?
So, any input would be GREATLY appreciated, for I need to do work before the end of the month to get it licensed.
Some triva reading from the report.
High speed test Idle test
HC(pass) C0 HC(ppm) CO%
STD 1.20 STD 220 1.20
Reading 2.79 Reading 364 3.72
deviation -1.79 Deviation -144 -2.52
Thanks Again for reading and the inputs:cheers: WoodyFJ80
I hope this is more understanding:
High Idle Test
__________________________________
HC(ppm) CO %
___________________________________
Standard 220 1.20
Reading 211 2.79
Deviation 9 -1.59
result PASS FAILED
Idle Test
____________________________________
HC(ppm) CO %
Standard 220 1.20
Reading 364 3.72
Result FAIL FAIL
Hope this is better to understand. WoodyFJ80
High Idle Test
HC(ppm) CO %
Standard 220 1.20
Reading 211 2.79
Deviation 9 -1.59
result PASS FAILED
Idle Test
HC(ppm) CO %
Standard 220 1.20
Reading 364 3.72
Result FAIL FAIL
Much better.
And "ouch" on those numbers!
Where are you at with basic maintenance such as plugs/wires/cap/rotor, timing, etc.?
Oh, and if (as far as you know) the O2 sensors have never been replaced, I'd replace 'em.
Curtis
If you are opposed to replacing them then you can test them with a ohm meter across the heater.
From 91 FSM
"Using an ohmmeter, measure the resistance between the
terminal + 8 and HT.
Resistance (Cold): 5.1 – 6.3
If the resistance is not as specified, replace the sensor.
If you take them out you can clean them with some compressed air as well.
Does UT have a limit to the repairs then they just give you a pass due to cost? I cannot remember but I thought CA had something like $450.00 in repairs was the limit. If so then you could just do your tune up and O2 sensors and thats probably coming close to the limit. Then just take the recipes back to the inspector.
In answer to the PM, plugs a year ago, wires,cap,rotor, and timing about a couple years. And as far as I know the o2 sensors never been done. Any other ideas that I could do to fix things???HELP PLEASE!!!
Hey ArmyFJ, no limits here(I think). Sounds like time to replace things. Ouch on cost. Better call CDan in the morning.. Please more ideas!!!!
As we all know CO (Carbon Monoxide) is produced by incomplete combustion.
Here is a link and some info from the same site;
"Carbon monoxide emissions are the result of an incorrect air/fuel mixture. In a carbureted vehicle, improperly working floats, power circuit and choke circuit could cause high CO. In fuel injected vehicles, improperly working injectors, pressure regulators, coolant sensors or MAP/MAF sensors could all contribute to high CO emissions. Some other common systems or components related to CO emissions are the air filter, PCV system, canister purge, O2 sensor and air Injection system. Due to the complexity of the internal combustion engines, there may be layered problems related to high CO emissions."
Wisconsin Vehicle Inspection Program - Motorists
I would check the basics, clean the dirty stuff, replace the air filter, check/clean/replace the PCV, run a can of BG44K in the tank, and depending on how many miles might be time to change some ignition components again; at least check/clean the cap and rotor. Is it running at proper engine temp? Idling smooth? Using cheap gas? Plugs gapped properly? Any air/vacuum leaks?
IME the 3FE needs to breath freely; I would be sure it has a new unrestrictive air filter.
x2 on all the maintenance checks. Another sneaky idea is to only have about 1/4 tank of gas in it, get it nice and hot, and then pour a full bottle of rubbing alcohol into it, just around the corner from the testing site. I've had some trucks in the past, and a 79 Heep, that wouldn't come close to passing before doing this, then passed with flying colors after.
Sounds like a great sneaky to me. I will try all the PM stuff and pulling out the o2 sensors and cleaning them. To Gray's thought: I did replace the MAF witha rebuilt. I noticed that the adjuster screw(on the front side of the MAF)has a tag on it with rich and lean adjustments. Would this be the thing that is throwing the high numbers. My tailpipe does have a black ring on the end and it sputters black smudge spots on the ground until warm. Any Thoughts????
Running rich until it goes to closed loop or until the catalyst heats up to reduce emissions.
Second time you've mentioned this, but I'm not sure what you're getting at. First of all, it's an Air Flow Meter (AFM) on our (91-92, at least) rigs, not a Mass Air Flow sensor (MAF). Second, I'm certainly not aware of any adjustment screw on a 3FE AFM.
Curtis
P.S. Heck, if there *is* an adjustment screw (which I doubt), go ahead and turn it and see what happens; what could it hurt as long as you remember where it was originally?
Sorry, your right its a AIR FLOW METER. I will take a pic tomorrow, also there is a check valve thats runs to the air pump(Drivers side) it seems to be rusted through, and the hose is pulling off(I will post pic tomorrow as well) It does seem to play a part with the emmissions.
This is a good point--do you know if the test was done with your rig warmed up or cold? A cold rig will definitely affect the outcome of a Two Speed Idle test--especially since you really failed at base idle.
Also, for what it's worth--double check your Repair Waiver regs--I did a quick google search and it looks like your Model Year truck may fall inito a repair limit of ~$200 to be eligible for a repair waiver. Pretty much every IM program in the states has a Repair Waiver element to reduce the financial impact on some constituents.
What county in Utah are you located?
yup, when I have my tests done, I always drive the truck for a while before, and then I keep it idling until the very beginning of the test so the cats are piping hot hopefully. I imagine it can only help.
Your numbers seem seriously out of wack indeed. Mine usually are much much lower than the average, let alone the max allowable.
In answer to #17 and 18 posts. I live in Weber Co. and also I was talking with my Mech. and we both agreed that I was testing with a cold rig. Just drove it down to the emissions place and turned it off and waited 15 mins or so, then restarted and did the test. The test place is a whole 5-7 min. drive from my house. So, I can understand about not being warm for the cat to do its job. Yes the "cat", I did replace the dual cats for a Single aftermarket, it passed great last year, well with the number limits. I am going to retry tomorrow and will post the results with a WARMED UP LC!! Let ya all know later! Thanks for the inputs! WoodyFJ80
It'll be interesting to see the results after the second test with a warmed up truck. Good luck!
