factory winch dilema.help..
so today i decided on wiring my factory a-1000 winch.. i made myself a nice wiring harness attached to a three way toggle to be mounted in the interior.. getting excited about using the winch for the first time so i plug the pins into the connecter to test if it works and all i get is a clicking sound on the motor side of the winch...which sucks.. does anybody know what the problem can be? and on the left side of the winch there is a lever they call a break should this move freely, mine does not is the maybe the reason why it doesnt work?
so the winch will not work in forward or reverse? I was under the impression the brake works automatically but have no experience. Are you saying you plugged in the winch controller to the factory terminal block?
How about a bit more info and some pics?
I am kind of guessing you wired into one relay but not both, or there is a relay that needs replacing. Be careful, if you wire it wrong and short youll go through power cables and batteries in a hurry, and could quickly fuse the relay closed.
yes that is correct the winch doesnt work in forward or reverse. yes i plug my harness into the factory connector.where is this solenoid{is it in the black box mounted on the winch? at first i did plug it wrong because im not sure which pin is the ground yet.. and i kept blowing 7.5 amp fuse for ignition.changed the fuse got the multimeter out again and got it pluged right.. it clicks when i go left or right on the toggle which tells me electrically it getting power.. can these solenoids be replace if it is the problem?
in warn, ramsey, electrical MM winch and factory Toyora winch can be replaced .. ( not sure others )
How much of the original wiring harness and wiring/switches did you use? You do know that there is a thermal switch in the winch which disconnects the power from the battery when the winch is too hot via magnetic switch #1 that was originally installed under the left side battery and that the winch remote completes this circuit?
okay do you have any idea where i could get this factory remote?
ok the click is it when you flick the switch, does it do it every time you flick the switch
if so then you are making the curcuit for the power only. you need to still make the up and down curcirt.
if your making incab controls youll need 2 x double pole relays.
go to slee4x4.com they have a wiring diagram for the relays.
if i have time over the weekend ill try and find my setup wiring diagram.
jono
so i pretty much figure out what wires are what. so i now got the solenoide for the winch itself clicking and the 2 solenoids for in and out clicking but still not getting the cable to move...im starting to get how it work but it wont, what is wrong...
mmm check to see if you have voltage at the motor when your winchin in or out,
i think you my have a burnt out motor
maybe it has something to do with the brake lever?doesnt seem to move at all!is this normal?ya i probably should check the battery. i was assuming it worked cause i was told it worked..will check that tomorrow.
to move the handel you need to push in into the winch then turn it ( slide it ). if it is disengaged the motor will still turn.
