You probably won't be able to start your engine if you merely remove the factory alarm CPU. You will need to re-connect the starter wires that are interrupted. Other than that you shouldn't have any problems. The starter wires should be easy to locate at the CPU with a volt meter. The in and the out just need to be connected together.
It would be better still to re-connect them where they are interrupted at the factory harness however. Unfortunately, I can't tell you with certainty where that is. On my 4Runner it was right at the ignition key harness.
