Fact or Fiction
Dusty 66
Ball & Claw Club
Nevada
Years ago.......... 16 I think when I destroyed the 1F in my 66 FJ40 with only 37.000 miles on it :mad:
I was looking for a replacment 1F and found one 100.00 but needed new pistons etc. talking to a TEQ at Man - O - Free that I had a 1F that needed re-building and wanted more gearing in the way of at least a four speed . He said that it might to be cheeper to find a 2F & bellhousing with H42 4 speed or go to a H41 or...........the outher option was a 4 speed that would bolt up to the 1F bellhouseing and the 3 speed transfer case:cool: .....! He did mentioned that thay were very scarce NON - USA with non sincro 1st , he might have one or two coming in the next shipment he said to call back later (pre - internet day's) in a couple of month's I called back he still did not know ,:doh: but the TEQ said M-O-F haddent had them in a while I never called back........I did not git a H # for this transmission is this TRUE ! was this real did toyota build an 4 speed for the F engine ? JC
There was also supposedly an option for a 4 speed with a single speed transfer case in the early FJ55s.
You'll be time and money ahead to just find a 2F with everything and bolt that in. You can also adapt the standard 'Cruiser H42 four speed to the 3 speed transfer case, provided the transmission is from 1980 or earlier.
Yes Advent and Big RedFJ40 you are correct !
I am aware that 25 series used a 4 speed with single speed transfercase.
but .... would this also bolt up to a two speed transfercase that was used with USA three speed transfercase?.... :confused:
as the M-O-F TEQ described this transmission as straght Bolt-Up with the Non-USA F type 4speed Transmission:rolleyes:
Advent I have since..... :cool: last year installed a 1978 2F with a H42 an used an adapter kit from MARK's OFF ROAD to use the 3speed Trassfercase
I' m a little S L O W :o
JC
Fact, just not in the USA. There is documentation of it being an option in other countries though.
The H41 did come in a ten spline output shaft, but I would think that they would all be rather old and worn. The newer 16 spline version has a syncro first and a higher first gear (4.8? vs 5.3?) Regardless, you could get a 16 spline H41 (similar case to the H42) and adapt it to your F and J30 case by running a '74 16 spline input gear and a H42 bellhousing. Since you have a 78 2F and a H42 you should be able to bolt a 16 spline H41 right in place of the H42 since you have Mark's "adapter kit."
:cool: So a F type H41 ten spline out put shaft did exist :cool:
So was the same one used with the single speed T case in the Early FJ55 ?
YEA I planed to go to a H41 later.......On since it's a bolt on job Now and the drive lines mods are already done :cool: ............. got to git paint done and back on the road first ! Thank's JC
My Oct 74 has a 4 speed and a 3 speed tranny. All stock.
Poser said:
1974 40's and 55's had an F engine and a four speed tranny...(H42) ;)
The 1973 was the last year for 3 speed J30on the floor USA model
So the 1974 FJ40/FJ55 USA model had an H42 with a 10 spline also H41 non USA model with 10 spline ..........Is This the missing link ? :cool:
We now need to find the H55 with that bolt's up to a one piece transfer case ! :rolleyes:
I posted this Question becouse have related this story before ..... and I would git less than positive responce ! :cheers: JC
Nope, the 1974 US model had a H42 tranny with a six spline output and a 1.99 low range. the input gear can be used with the J30 case. After that (1975) the case is a 1.96 and the input gear is specific to that gear set.
The ten spline h41 was around the same time as the J30 three speed in 55s. When the h42 four speed came out across the line all Cruisers then had two speed cases and sixteen splines.
Quote:ridgerunner 24 forward gears and 8 reverse. Cool.
HOW did this work ? :confused:
Also you are said that early 1969 FJ55 USA model had say an option H41 ?
DID all years USA FJ55 model have this option or just the early years ?
This transmission did it have a two speed transfer case ?
Also was it a Non syncro first gear ?.........Very Very Interesting......JC
