Just got some plates for the frame horns back from the cutter. My initial plan was to cutout blue area (to make room for body mounts on the outer plate) and bolt on the plates in the rear (red holes). and either bolt in front of the body mounts---or weld. (?)
the plates are 3/16" and i plan to run one lower 2"dom (.120 wall)crossmember in between the frame as well as one main wraparound tube.
i plan to box the underneath so the stock bolt holes can be used---- and cap the ends.
My question is --which is stronger-bolt on or weld on???? obviously welding is easier----but i thought bolt on would be nice and some people may like a few of these produced.
