F2 4 speed shifting question
Houston
Haven’t had an opportunity to drive an original FJ. Are you able to shift into first gear without applying throttle or does it stall?
Not sure what you are asking.
The clutch must be depressed in order to select first or any gear while the engine is running and the vehicle is not moving.
From a dead stop on mostly level ground in first or reverse the clutch can be released at a moderate pace and the engine will not stall.
