F Vs 2F
Hi everyone,
This is my first post on this board, but I have a 69 FJ55, with the F engine, it is smoking (making me and the wife gag), and now has developed a knock. I think it is bearings.
I have heard some rukus and opinnions about changing to a 2F engine, but frankly I haven't heard a list of good reasons to do it.
Also there doesn't seem to be any low milage good used (guarranteed) engines close enough to just drop by and pick up.
I am in Southern Utah. Anybody want to rant for me about this? I would appreciate perusing all of you opinnions and experience.
I am about to drop off my pigge for an overhaul, with a local reputable ex-race car expert. Looks like it can be done without me laying a finger to the job, including R&R for $3500.
He is locally known & recommended. The dough-ray- me is the hardest part, but worth it to have her running right again.
I have grandsons chomping at the bit to go trail running. And truth be known I am as excited as they are!
Thanks Kelly FJ55
69FJ55
Front& Rear Disc brakes
Power Steering
There is some info in the FAQ for this forum, but there doesn't appear to be that much info on the F. There is also a short statement on the Birfield.com FAQ. I'm not expert, but the 2F is bigger, has more horsepower, and the 2F has better oiling capabilities compared to the F. However, there was an article in Toyota Trails several years ago about how to improve oiling on the F. If you're going to stick with the F and rebuild it, this might be the time to do that fix. Someone here should know if that fix is posted someplace.
you can find decent used motors, F or 2F, but if you put a 2F in your 69 pig then you'll have to change to a highhood from a later pig. to get air cleaner clearance
How much taller is the 2F? I am using a Weber 38mm would that fit with out the new taller hood?
When I did my swap I rid the 2F of it's extra weight (smog crap). Then I used my F intake manifold and F air cleaner. This kept everything where it is suppose to be. This was on a 40 not a 55 but should be the same I think. I'm far more comfortable with oiling of the 2F vs the F.
Welcome to mud with the Pig
Chris
