F or 2F?
Bonita, Tx
Stupid question here, but what are the differences between the F & 2F.
Thought I had a 2F in my 75 FJ40, but now think it may be an F.
How can I tell?
What makes you think its an F?
On SOR site, here are pictures of an F and 2F.
Maybe I should rephrase my question.........is there a possibilty it could be an F?
Am told it's original engine. Were the F's typically on the older models? Other than smaller displacement, was curious if there are any major, visible, tell-tale differences.
Try this link. If you can read the serial number, it should tell you
http://www.sor.com/fengine.html
Also, it is possible to use peices from both types to rebuild one engine. Not all, but I believe the block at least can be switched. I am sure others will correct me if I am wrong.
Found the # (on the block, under a layer of grease) 2F it is. Did not know
that was where the block ID was, thanks Ken.
