F.O.R 3" Castor
Just replaced the tie rod ends and went to the alignment shop.
In August I purchase Frankie's 3" lift. He left it up to me to decide on 2degree or 3 or 4 (I can't remember) degree castor correction bushings. Due to his experience and input on the larger correction I decided on the 2. He claimed there was a pretty good chance that there would be steering wheel wobble with the larger correction. I drove his 95 with the 3.5+ lift with larger correction bushings and definately noticed. Also, due to the smaller lift and phase of production, I felt obliged to give it a shot.
WinAlign Laser reading. DS: 1.5degree---- PS: 1.18 degree.
Although I am happy with the way the vehicle handles, I am definately curious as to where the 3 degree will put me and what type of improvement it may hold.
I also just removed the fender flares and discovered by just eyeballing the rearend that I am now in the market for an adjustable rear panhard.
Thoughts?
Input?
Questions?
Baumber
Those are good numbers for the OME bushings. I'm not sure what you mean by steering wheel wobble by having more caster, but you may have a chance of front driveshaft vibration.
At over 1 degree if you are happy with how it drives I'd leave it alone. People have done well with the higher correction bushings using Landtank's bushing template for axle centerline rotation.
What are you trying to solve here?
I run a rear MAF 4+ panhard for visual reasons. My front is stock.
With my Tencha ( HJ-60 ) at negative caster numbers usualy you get dead wooble .. but in Marilu ( HDJ-80 ) never get ( with suspension and not caster correction ) now with slee caster plates drive way better but barely over 1º of positive caster ..
main.php
I'm very familiar with what you are dealing with here. I just installed a FOR 3" kit myself. I spoke with Frankie quite a bit. He sent me both the 2 degree and 3 degree bushings at no extra charge to try out both sets if need be.
Post lift my caster was -2.2 and -1.7. I just put the 3 degree bushings in last weekend. I used Landtanks template, and it does rotate the axle downward a good bit. Even with using the template, the front control arm bolt holes did not line up perfectly. The template was designed for Slee Blue Bushings and my bushings were from Frankie and apprently sourced from Australia. I had to grind a tiny bit off of the mounting bracket to get the bolts in.
I only got to drive the rig a little and took it to about 60 mph. I felt no vibrations, no funny noises, just way better steering feel and handling.
I have to get some alignment numbers to see where I am really at. I can obviously tell I have gained more caster. I also have to test it out a bit more to see if I am indeed vibe free.
My suggestion is this: if you are happy with the way the truck handles and tracks, leave it alone. Although more caster should make it drive even nicer, according to the gurus on here. Personally I think everyone is a little too caster crazy on here, spending a lot of cash to get in the preferred 2 to 4 degree range. By going to the 3 degree bushing you may be inviting vibes. Then you either have to go back to the 2 degree bushings or go full caster plates and a DC shaft. Lots more money. Bottom line is if you're happy and it drives safely, let it go IMOP.
And I agree with you and NAY, the rear axle is visibly shifted. The front seems fine to me though. I just ordered a Slee adj rear panhard, so that will straighten out that.
Lastly, what do you think of the FOR setup? I will do a write up on mine shortly. But I love the way these shocks and springs work together.
Landtank, the Slee template came very, very close to being a perfect fit w/ the Aussie bushings. Maybe off 1/16" front to back. Frankie made it sound like he wanted to get some templates made by you to supply with his kits. Also, thanks so much for supplying the template. It made pressing them in really easy, and rotated the axle on it's center just like you said it would. I will post up some real caster readings as soon as I get it on the rack.
The spacing problem comes from how much offset there is in the hole position. The front and rear bushings are at a different radius from the axle's center and the offset plays into how they get positioned to maximize the effect and still have the proper distance between the holes.
Frankie knows where to find me and I'd be happy to help him out.
My mistake, the vibe I described would stem from the driveshaft. I am not necessarily trying to solve anything. I post these observations for those interested in lift options or just plain input from experience. I've taken plenty info from Mud; including the observations you've provided Nay. Just tryin to give a little back. :cheers:
Cstamm, glad to see you post. Also, you've got the luxury of having pre-castor numbers. It would be interesting to feel the driving experience difference in the 2 bushings/degrees. Hmmm, Leesport.... 8 hrs from here.
I am quite pleased with the feel and handle of the setup so far. Though, I have put off the trails until I get some armor which is currently in the works.:cool:
Let me know if you're ever coming out my way. I'm not planning any Western jaunts anytime soon unfortunately. I'd also love to get with someone who is running some type of OME setup to do a direct comparison on ride quality. Nay seems to be one of few who has direct experience running both setups. I love my setup, but cannot compare it to OME.
Sweet :cheers:
FWIW, I'll probably do Slee's bushings one of these days just because I'm curious. Caster is OK with OME bushings, no issue at all for a rig on 35's...but prolly could be a bit better. Nothing to get me to spend coin on caster right now :D
https://forum.ih8mud.com/showthread.php?t=179220&highlight=F.O.R+LIFT
FYI see this thread. Norcal Sam has some rave reviews.
I will keep you posted on travel that way as I have a fishing buddy in the York area.
Sweet :cheers:
And if I can ask .. how much caster you have right now ?
I don't know...went to a shop that ended up not being able to print me out specs...
My guess is between zero and one. Slightly darty, nothing major. I'd expect to be a bit under 2 degrees with Slee blue bushings...I'd also expect the possibility of vibes I don't have today...
And it drives in straight line with this diference of caster between right and left side . ?
I think almost all of these have a difference in caster between left and right. After my lift and before I put in the bushings, I was at Left -2.2 and Right -1.5 So that would most likely mean there was a difference in caster from the factory.
Yap I know always you have diferent caster between L and R .. but just wondering how much can cause driving issues ..
I dunno...I always figure that aging MT's overwhelm the other issues anyway :D
damn ... I must read this before .. :D
