F Engine - Preventative Maintenance while pulled
Denver, CO
I'm pulling the stock F engine from my 73 FJ40 and getting ready to put it in my 72. The PO had it sitting for years and I haven't driven it more than 10 miles in the 6 years I've owned it. The engine seems to be fine and compression is good. It leaks a lot of oil and I plan to replace the rear main seal, oil pan gasket and replace the clutch, TO and pilot bearing. Is there anything else that would wise to replace now while I have the engine out and transmission / bellhousing off?
@GregoryB
1. only use OEM seals on the front and rear crank seals.
2. Consider replacing the cam end plug at the rear of the engine:
Also the oil galley welch plug at the 10 o'clock position on the picture in the thread above.
@GregoryB
Thanks. I'll add these all to the list. Do you recommend a sealant for the welch plug?
@GregoryB
From an F, 2F engine master:
This is incorrect in 2 ways.
First, a Welch plug is a very specific type of convex round plug w/ a sharp edge. It is installed in a hole w/ a stepped bore. The plug has to be beaten flat once installed to expand it for the proper seal/press fit.
Second, 'freeze plug' is hillbilly slang for a core plug. Core plugs are used to plug core out holes in complex castings (engine blocks, heads, manifolds...) that are used to clean out the casting core material (usu. sand). Core holes are usually finished to a smooth bore and sealed w/a press fit cup plug. Vintage engines may use a welch plug for this purpose, but manufacturers got away from them ASAP, because of the more expensive machining and installation cost. Aviation and racing engines may use threaded core plugs.
The proper sealant for either a welch or cup plug is Permatex #1, hard setting. Silicon RTV sealers are actually slippery which is good for gasket expansion, but bad for mechanically retaining a plug.
A cruiser tip for the rear oil & cam plugs: If there is a concern that the plugs might leak or pop loose in use, fill the outside of the plug w/ JB weld, put a piece of clear packing tape over the plugs, then immediately bolt on the BH. After goop has hardened, remove BH, peel off tape, proceed w/ engine assembly as normal. Solid goop will insure that internal oil pressure cannot blow plug out to back of bore and really gush oil.
That's all I got.
Happy holidays or bah humbug, your choice. :cheers:
