Extremely rough idle!
Have you ever replaced you spark plug wires? or distributor cap/rotor/spark plugs? Gotten the engine compartment wet recently? Any check engine light?
Is it just a sensor?
Are you capable of doing some DIY diagnostics? We are going to need a little more help or we will just be shooting in the dark. There are a few things that we have seen cause these symptoms but you should not start throwing parts at it until you narrow down the cause.
First, a little history would help. What year and engine do you have? When was your last tune up? How has it been running lately? Maintenance history (HG? Intake cleaning? Fuel Filter?)
Next would be to isolate the problem to fuel, air, or spark. If you don't know how to do this then let us know and we can offer some fairly easy tests.
As for the likely suspects....
* Intake hose. These crack with age and when they get bad they take in unmetered air and the engine will run poorly.
* Fuel problems. The engine wiring harness on the 1FZ-FE runs next to the EGR valve. It will get hot and melt wires. When these wires short, strange things start happening and the engine may run poorly.
* Fuel filter or fuel pump or fuel pump relay. These can cause the engine to run poorly (or not at all.)
* Ignition. A bad plug or plug wire can cause the engine to run poorly.
Help us help you by giving us better information.
-B-
remember if all else fails KISS
(keep it simple stupid)
do the simple stuff, tune up etc, then do the more indepth stuff starting with what costs the least amount..
This is just pissing in the wind unless you give us more info as -B- has noted (#4).
Sorry about the lack of info... I was in a hurry for a wedding when I posted. It's a 95' with 150ish K on it. I'm not sure as to the tune up history as it is still technically my fathers vehicle but I doubt it has had a tune up recently or the cables/distributor and rotor etc.. changed recently. It was running fine till the past couple of days then I had to disconnect the battery so that may be it as well... I recently have had the check engine light on for quite a while because I got the engine wet about a year back. I was not as knowledgable back then so never thought of the cap and rotor etc... It may have been the O2 sensor out as well. The check engine light also disapeared when I had the dash off for a heater core swap and a mechanic friend of my dad's finished the assembly of the dash. I am hoping that the check engine light didn't turn off because of him not connecting it! If it is the battery being disconnected how long does it take to re-learn and run proper?
Usually 4 or 5 start cycles.
-B-
