Has anyone come up with a good way to have external main (starting) battery isolation and charger connection possible with an 80? Ideally something using a special Anderson plug that would allow something like a Ctek or similar charger to be connected.
Don’t think you can or should isolate main battery, it’s supporting things like the clock, radio and ECU. There is no reason why you can’t just slap a charger on though.
Yeah didn't think about clock. There's no ECU in my 80 since it's diesel, and the sound system is aftermarket fitted by me powered from aux battery. Was just curious.
On mine I wired one of these Flaming River Battery Disconnect. It completely isolates my second battery and also the positive cable that comes from the main battery to the starter. It kind of acts like a security function as well but does not interfere with the fuseable links so things like the clock and ECU are left powered. I never bothered with the Anderson connector for charging.
If you have a diesel 80 with factory dual batteries then your starter is 24 volts. You wouldn't want to isolate any of the batteries because they are identical and wired in parallel except for starting where they are momentarily conencted in series for 24 volts to the starter. If you isolate them, one battery will discharge more than the other and you will run into more problems.
If you have a 12 volt starter and an aftermarket dual battery setup, then you probably have an isolator anyway, unless you have the second battery connected in parallel directly to the main battery.
Is that true? I thought the entire system was 24 volt always, meaning 24 volt accessories or using some sort of 24 to 12 converter if you needed 12 volts? Educate me please.
In the 80 series with dual batteries, the entire system is 12 volts except for the starter which is 24 volts. Lots of info in the diesel section of this forum
Starter is definitely 12 volts in my diesel 80 - it has a direct connection from the +12 volt terminal on the main battery. Perhaps the LX450's were set up differently? There are some diesel 80's with a 24 volt starter but most 80's never had dual-batteries. My duat-batt setup isn't factory btw.
Because it's now getting into the cold season here (cold for Aussie land) batteries and things related to batteries tend to play up more. Always been a bug bear to run a power lead on the ground to run a charger kept dry sitting under the slightly propped up hood/bonnet with the neg terminal isolated off the battery.
If charging is all you're concerned about, just disconnect the positive and negative terminals on the aux battery, and charge both batteries separately. That's how I do it with my HDJ80 and VDJ200 occasionally to balance the batteries. Aux battery disconnected, then both batteries hooked up to two Ctek MXS 5.0 chargers. Make sure the positive terminal is insulated when you remove it from the aux battery. I do have a Ctek comfort connector hooked up to the positive terminal of the main battery and the negative terminal of the aux battery so I can charge them together with one charger and this is how I usually charge them.
