Exterior Window Trim
If you remove them carefully.. Take your time.. and then also peel and scrape the platic off.. They actually look quite nice.. I did it on mine.. odly enough only one side was showing sun damage DS on both front and back PS was all looking like new so I just peeled the DS doors and NO-One has ever noticed.. I will defenitely peel the PS if they go bad.. I thought of painting them to match but they actually look quite nice in chrome.. And as I mentioned before NO-One will notice even at the cruiser meets unless you tell them. ! :p:hillbilly:..
I plastidipped my headlight chrome. That was over a year ago. It has held up well. I wiped the chrome with MEK but did not sand.
Plastidipped my grill and TOYOTA emblem and it still looks like the day I did it.
I plastidipped the painted metal below the grill and it didn't hold up well. I didn't sand it. Just wiped it down with MEK.
Thanks. I put 3-4 coats on last night and installed this morn. Honestly I could live without them. Painted gutters underneath looked good but I'll try to be a purist as long as I can
went through a similar issue with the under-window trim on my Acura (supposed to be black, but had chrome showing through). Peel all the black stuff off, pop off the whole trim piece and wrap in black vinyl. All done for about $20. :D
My window trim pieces got pummeled in a hail storm, so I replaced them. $62ea from Beno. The long pieces that snap over the rain gutter weren’t as bad off, so I sanded, shot them with adhesive promoter, then painted them with a flat black. Just did it about a month ago, so can’t speak to durability.
If you’re planning to refinish the door trim, one word of caution: be careful removing them as the clips are brittle. I broke several when removing mine. If you order them, the pieces are called belt line trim and they come with new clips.
Maybe worth mentioning, the belt line trim clips are available separately from Toyota as well.
