For Sale Expedition Trailer with Mt Rainer CVT RTT Tent - AZ
Hello,
My trailer is up for sale. It just received a nice kitchen upgrade along with an inspection. I just got the trailer weighed at a certified. I am not giving up on trailer life. I simply have an opportunity to move into a production trailer once this one sells. If it doesn't that's ok too.
The trailer is based off of a M116A3 Military trailer platform and has been heavily modified to become a great offroad/overlanding trailer. It has been used on the following trips in the 15 months since its completion: Utah Border to Border, Baja Mexico, and the Idaho Border to Border route along with countless other trips both on and off-road. It is a proven platform with over 10,000 miles of use. Completed in May 2015. Fairly unique design based on the Turtleback trailer. I wanted to build a DIY version with a similar design.
The major differences between this trailer and a Turtleback is it’s a bit larger, more storage, and interior finish are not as polished as a TB (other than the kitchen), and of course the frame was a military trailer with the added box vs being built in a production facility. I have been 100% happy with this build. Lots of smart/skilled people helped with it. It is a great platform ready for your own adventures. The trailer just received kitchen upgrade and inspection with no issues found.
Price: $10,500
Features:
  • Torsion axle - UCF Flexride patented suspension system (Exactly the same axle as a Turtleback trailer)
  • Toyota bolt pattern, can be changed. Comes with 2007 style FJ Cruiser rims. No spare. Tires have less than 10,000 miles on them. 265/70/17 former un-used spare tires. (Rims pictured not included)
  • Wheelbase matches an FJ Cruiser.
  • Electric brakes
  • 32 Gallon Water Tank Easily accessible water tank fill and drain handle
  • On Demand Water Pump with Commercial Grade Plumbing
  • Atwood On Demand Hot Water Heater (Built into the trailer not exposed)
  • Single AGM 75AH Deka Deep Cycle Battery with solar controller.
  • Solar charging port on side of trailer or on battery box for solar kits with their own controller
  • Slide out kitchen with dual burner stove and sink with foldown faucet. Baltic birch professional quality cabinetry from Turtleback Trailers.
  • Kitchen area includes a dual USB charging port and 12 volt plug. On/Off switches for the gas, water pump, light and water heater
  • Vented sink drain line with option to hook up a hose or use 5 gallon bucket
  • Auto off gas safety switch. If the drawer is closed while the stove is running the gas will cut off.
  • LED light bar on front of trailer and in kitchen area
  • Interior light for cargo area with on/off switch on both sides of the trailer
  • Simple electrical panel with a BlueSea fuesblock, On/Off switch, and solar controller.
  • Production model quality aluminum doors and storage boxes. All with locks
  • Shower head with hot/cold knob with locking door
  • Tank-fill port with locking door
  • Harbor Freight large tongue box (Battery in battery box mounted here)
  • Shore power plug on tongue box with Noco charger
  • 2 Fuel can holders in front (Hold 5 gallon NATO style cans gas cans not included)
  • Quality round tube roof rack which can support a large RTT
  • CVT Mt Rainier Tent included in price. (1yr old) Upgraded to a more dense foam mattress but also have the original CVT mattress if you wish to switch
  • 2 - 11lb Propane tanks with steel propane tank holders. One is for the kitchen and water heater and the other as a spare or for your grill, etc.
  • Tons of storage including the front area which can hold up to 8 FrontRunner boxes. 3/4 of the top deck is available storage. A 10x10 EZ-Up can fit inside of the top deck length wise.
  • Open receiver hitch on trailer to accommodate a Max Coupler or your choice of trailer hitch. Max Coupler included
  • Aluminum skin no rivets
  • Recovery points front and back
  • OEM stabilizer jack in back
  • Standard jack in front and heavy duty XO Jack with dual wheels. The XO jack makes it very easy to move the trailer both on hard and dirt surfaces.
  • Wired for 7 pin plug to charge the battery and electric brakes
  • Safety cables vs chains
  • Exterior covered with Monstaliner bed liner.
  • It will fit in a standard height garage
  • Titled in AZ with VIN
Dimensions:
Box Dimensions:
44.75" Wide
34" High
89.5" Long
Total length of deck: 97" includes fuel can area.
Tongue length: 42.5"
Total length of trailer back to front of the receiver: 140.5" (11.7ft)
Total width of trailer: 72"
Deck Height: 26"
Total Height of trailer in center (ladder): 80”. As long as you don’t have an additional mattress inside of the RTT this trailer will fit in a standard height garage without having to air down the tires.
Front Door Dimensions: 21" Wide X 28" High
Trailer Weight:
Weighed at a certified scale both empty and with all my stuff. Nearly bulked out as if I were doing a 2+ week trip.
Empty No Water - 1775
With 32 gallons water - 2040
With gear including 10 gallons of fuel - 2320
Trailer no tent or water - 1625
This puts my trailer within 100lbs of a base Turtleback trailer (single battery, stock tires). I'm very happy with that.
Here's the build thread with lots of photos: M116A3 Trailer Build Takeover - Expedition Portal
Old tent and old kitchen are in these photos
Tent Specifications:
Mt. Rainier Standard Pioneer Series :: Cascadia Vehicle Roof Top Tents
Issues:
  • Plastic Ladder knobs tore off but you can still easily retract and extend the ladder.
  • Small tear in RTT cover zipper fabric at beginning of the cover.
Dogs love it too!
Latest Mod: LED Taillights installed and interior rails all re-painted to clean them up.
I just finished applying a new coat of Monstaliner on the trailer to clean things up after its many adventures. One deal fell through so this trailer is still available.
Oh hey there! BUMP
Just an FYI this trailer is coming up for sale again. I have kept in contact with the current owner. The trailer is in Tulsa, OK. So if anyone was interested in my trailer in the past I will post up a link when he posts something online. Awesome trailer. There are times when I miss it.
He added a Foxwing awning and it now has Landscruiser hubs and rims.
Just an FYI. If anyone is seriously interested shoot me a PM and I will give you the current owners contact info. He is a solid guy and consider him a friend now.
