For Sale Expedition Built -1989 BJ74 For Sale
Kelowna, BC
70 Series Landcruiser
Model: 1989 BJ74
Engine: 13BT 4 cylinder turbo diesel 3,400 cc
Transmission: H55F - 5 speed
Gear Ratios: 4:11 differentials (4.44 with Marks under drive)
Rear Axle: Full Floater
Low-Range: 3.05:1 Marks low range (from 1.97:1)
Odometer: 122,600 miles (196,210 km)
Steering: Power RHD
Accessories: PS, AC, power locks, power windows
Imported: 65,600 miles (105,000 km) in 2006
Serviced by: ATEB (diesel Landcruiser specialists) in Vancouver and Millson Motor Works
Basic Description
The legendary 70 series heavy duty Landcruiser came with the 13BT, 4 cylinder turbo charged diesel between 1986 to 1989, a follow-up from the classic 40 series. This truck comes with a 5 speed manual transmission (H55), split case transfer case (1.08/3.05 Marks reduction gears), factory AC (blows cold), electric windows, power door locks, factory PTO, 4.11 differentials, fiberglass removable top, electric mirrors. The truck gets over 19 mpg (US). The color is two-tone black and silver. The truck frame and body are rust free.
This BJ74 has been modified for expedition use, and only the best parts and equipment have been used, Toyota OEM or better quality aftermarket parts from Australia. I have an extensive maintenance history since I acquired it in 2006. Included is the backseat, spare front cab carpeting and Factory Service Manuals (engine and chassis), printed out in two big binders.
Tires and Suspension
· 315/70R16 Cooper Discover STT (35") tires.
· 16"x8" Mickey Thompson II Classic alloy wheels
· Front differential moved 25 mm forward
· Old Man Emu Dakar suspension lift.
· Terrain Tamer Shackles.
· 4 degree steel castor correction shims.
· 1" body Lift
· Man-a-Fre U-Bolt Flip Kit
· Extended Shock Mounts
· Rancho shocks (fronts are adjustable).
Drive Train
· Front and rear ARB air lockers
· 24 VDC ARB compressor (dedicated to lockers)
· Marks Gears (1.08/3.05 low transfer)
· McNamara Gear (solid spline transfer output gear)
· Transfer case rebuilt (Koyos)
· Full floating rear axle
· Rear Wheel spacers (Spidertrax - red locktite)
· Exedy Sports Tuff Clutch (new)
· Knuckles rebuilt Koyo bearings (early 2014).
· Front spindles recently replaced (early 2014).
· Front calipers recently replaced 2014 (Toyota factory reconditioned).
· 24 volt 3/4 hp PUMA air compressor (tires, air tools,100% duty cycle)
· 4 tire inflation system (4 hoses to compressor with gauge)
· Speedo correction gear
· DBA slotted front rotors
· PBR ceramic front pads
· SS brake lines
· PTO winch (all 4 U-joints replaced with Precision greaseable fittings)·
· 3/8" Amsteel winch cable (crush proof thimble)
· Custom 2 1/2 " stainless steel exhaust system
· Fuel timing just reset (improved throttle response)
Electrical
· H4 Hella headlights (just replaced)
· Gauges - Isspro EGT, VDO water temp and boost
· Dash mounted LED digital voltage gauge
· Hella Rally 400 Off-Road lights (100 watts each.)
· 900 watt 24 VDC to 120 VAC inverter
· 20 Amp Samlex 12 VDC converter
· Sony tuner/CD player (line-in), with Pioneer 2 Way speakers in rear doors
· 80 watt solar panels (2x40 watt) roof mounted (monocrystalline silicon panels)
· Morningstar MPPT charge controller (Full charge with fridge on - indefinitely).
· Marine grade wiring (tinned copper)
· Uniden CB radio
· Adjustable FireStik CB antennae.
· Antitheft light deterrent (switchable)
· 24 VDC 12 VDC trailer light converter.
Interior
· Closed cell foam matt in cargo area
· Custom steel rack for Puma and ARB fridge
· Ammo box shelf built into rack (with box)
· ARB fridge (24 VDC) with top baskets and insulating blanket
· Two extra 12 volt power plugs
· Cargo light (24 VDC)
· Fire Extinguisher.
· Custom overhead storage rack
· Custom fabricated storage console box (top flip storage with 2 lower drawers).
Armor and Exterior
· Custom sliders (running board with kickouts)
· Custom winch bumper (two 1" recovery points)
· Custom stainless steel bullbar
· Custom limb risers with stainless steel fittings
· Custom rear bumper with 24VDC 70 watt back-up light
· Trailer hitch
· Custom dual 20-liter (5.3-gallon) Scepter diesel fuel can swing out
. Two 20-liter (5.3-gallon) Scepter diesel fuel cans (Scepter diesel nozzle)
· Custom storage basket on swing out (keeps propane, chainsaw fuel out of truck)
· Custom fabricated full size TIG aluminum/SS roof rack (8 supports)
· Roof rack has outrigger bars for canopy support.
· Custom hot water heat exchanger (outside shower with hoses).
· Safari Snorkel.
· Donald 'Top Spin' precleaner (cyclone rejects dust prior to intake - works well)
This truck comes complete as described above. This is one -of-kind expedition Landcruiser ready to go anywhere. I would not hesitate to drive it to Central America next week. It carries 35 gallons of fuel (130 liters) and has a highway range of nearly 700 miles. The 80 watt solar array will keep the fridge at 35F and the two batteries fully charged indefinitely.
Issues
A few minor dents, but overall the truck still looks great. The truck looks like a wheeler and could do with a paint job.
$20,900 USD
You should repost it here Glen. Anyone who buys this will have a very well thought through and meticulously maintained truck
Interior
Interior
chassis
chassis
Rook Rack and Solar panels
Out there
I can vouch for this truck, as I've seen it in action a couple of times. It is an amazing machine. Very well thought out with no expense spared. I'm sure the buyer will be very pleased. Good luck with your sale Glenn.
Here is pictures of the full spline McNamara gear (with straight cut PTO gear) - it replaces the original transfer input gear - this enlarges the spline contact length on the transfer gear shaft into the split case. Australian aftermarket upgrade. Both McNamara and Marks Gears are in Melbourne, Australia (in fairly close proximity) so I had the Marks gear made up with McNamara gear for the full spline upgrade.
New Price $20,900 USD
New Price $20,900 USD OBO
Unless you have time constraints I wouldn't lower the price anymore. It's easily worth what you are asking. Even though more and more 70 Series are coming to market, the really good ones are few and far between.
This truck would be a dream of mine. Don't suppose you would consider trade for my 06 Tacoma with some extra $. 100k Km, fully expo'd. Rear elocker/Dual Batt/Front & rear custom bumpers/winch/heat exchanger & water pump/modified roofrack & awning/pinstriping... Many other tasteful upgrades.... Not many vehicles I would even consider trading for.
an excellent unit ! very well thought out! It gets better every year!
I just checked my spreadsheet that tracks all the money I spent on my truck and shed a few tears. Someone is going to get a screaming deal on this truck!
