Tried the search but didn't see anything here guys. My exhaust is clanging and rattling at idle so looked underneath and two brackets the hold exhaust are broken from pipe(rust unfortunately). One is right after 2nd converter if I remember right and other is by muffler. My question here is should I go ahead and upgrade entire exhaust due to rust or just have two new brackets welded on to hold factory exhaust up for a little longer. From what I've read aftermarket exhaust doesn't add much hp and I'd like to keep the exhaust as quiet as possible. Getting to my question is anyone running an aftermarket exhaust that isn't too much louder than factory and what did you do about the cat's? Thanks as always.
So I went to the completely toothless muffler shop right across the street from my work with the dirtiest, scariest shop you have ever seen and $35.00 later he spot welded the one bracket back together and added a cheesy universal strap by the other one. It looks like hell but it works great!
More money for the lift and tires and replacing the ridiculously expensive carrier bearings and pinoin bearing!
