exhaust size
Ventura, CA
Website
teqtach.com
So I am going to be installing a GT2052 on a 13BT manifold onto my 2B in the next week or two (as long as all of the boxes show up!)
I will do a write up with pictures and all of the sources for ALL of the parts. So my question is about exhaust.
IS there any advantage to putting in a 3" exhaust? I have heard that I may not get a huge power increase, but it may help EGT and spool of the turbo. I have also heard that a 2.5 is fine and gives a little more backpressure.
BTW: Heard means read on here through search!
Thanks for any feedback.
K
K
3 inch IMOP is a waste. I used 2.5 on my Bj60. I think 3 inch will not have enough pressure too. I'm thinking for water crossings. The 2.5 may stay clear..??
But I have 0 temp issues(egt) with my 2.5 So I see no reason to go to 3 inch. It's a small displacement engine. Not a cummins or v8. Save you money.
BB you are right about the 3" and water crossings.
i lost a perfectly good 2F engien a couple decades back when crossing a pond with 2 1/2" exhaust. i was idling across when the water pressure became too much and kill the engine. the water worked its way back up the exhaust flooding the cylinders, bled into the carb...
if you do run the oversized exhaust keep your rpms up to prevent this.
the 2 1/2" is plenty for all the "B" series engines...
