exhaust routing
atlanta
The archives have informed me that the best routing of the exhaust is for it to exit PS or DS behind the rear tire. Unfortunately given I have a 79 FJ40(underbody gast tank), Aqualu tub with drop down storage box in rear, and I have flipped my rear spring packs this exit strategy will not work.
It appears that my only other option without hacking up my rear drop box is to exit the exhaust in front of the tire. If this is my only option I am inclined to route it over to the PS so that it is at least away from the driver.
I would like to hear about others who have the exhaust exiting in this location and if there have been any issues.
I will have it tucked up inside the wheel well so it should be proteted and it does not appear as if the tire would be an issue given the flipped rear springs.
ALF
mine was there with the F engine for a while. Just make sure you have armor to protect it, an engine that has a plugged exhaust doesn't get far.
My duals exited there for the last 2 years or so. LOTS of stink with the top off and no doors. Some stink with the top and doors on because of my leaky, worn out weather stripping.
I cut some short exhaust tubing at a steep angle and welded short sections onto the tips of the tailpipes. This helped direct the exhaust downward and reduced the stink some, but not enough. Maybe if you made the turndowns longer it would work better. (Only pic I have kind of shows the turndowns.)
Theo, is there some Cadillac Eldorado missing a set of seats some place? :D
Custom Exhaust
I had a welding/muffler shop design a system for my 67 FJ40. I previously had dual exhaust (chevy 350) running under the frame and exiting in front of the rear tires, but crushed the pipe between rocks and the frame numerous times. The shop combined the two 2" pipes into one 3" pipe inside the frame next to the tranny (DS). Then a staight (cherry bomb style) muffler, mostly protected by the skid plate ... straight back with a hump to allow compression of the rear axle. Exit the frame behind the rear bumpstop, and out the driver's side rear corner.
Hope this helps :cool:
I'll bet a creative exhaust shop could make it come out the back. I have a 79, but without the rear drop box. Mine goes down the drivers framerail , up around the side of the gas tank, and the muffler goes across the back and exits out the passenger side behind the tire. I would think if you used a glasspack style muffler, it should be able to sneak out the drivers side next to the drop box. But you may need to have the muffler pretty far towards the front, depending on clearance next to the drop box.
There is just no room to get it around the drop down box. You can go on the outside of its but then you are in the wheel well area. I may be able to go under it as this area is not very prone to impact.
I may just have to settle on PS side in front of the wheel and see how it does.
ALF
