I think if I remember correctly, when I pulled mine out and cleaned up and re-welded the flanges on the exhaust manifold's. It is quite possibly the cheapest set up they could get by with and it failed miserably, the material the exhaust manifolds are made out of might at the most be 16 gauge material. I had just barely enough studs extra on hand, I ordered eight I believe, and used six(three on each side) on the actual collector portion that goes down to the catalytic converters, and only replaced two that went into cylinder heads. Both use the same studs and nuts.
As far as procedure, my 100 series spent most of its life in the desert southwestern part of country so is basically rust free-keep that in mind as you might need all new studs and nuts. I took off the three nuts from exhaust manifold flange to catal Unbolted drivers side engine mount, and jacked drivers side up using approximate 12" long 2x4. The heat shield was a bit unnerving, and was a pain, and so were the rest of the manifold stud nuts, but I think only two studs came out when I did the drivers side, so I just replaced both of them with hardware on hand.
If you have a large assortment of extensions, like two to three long ones, same number of short ones and several universal joints- you can get to all of them using patience and without having to remove any further components.
Drivers side took me a solid, almost six to seven hours, but that included me removing exhaust manifold fixing exhaust manifold flanges, cleaning them back up with some carbide bits, new manifold to cylinder head gaskets, then having to weldup a stud hole or two, locate, drill and tap flange studs locations on the collector flange mount so that I could salvage the stock manifolds. Then fought with manifold alignment into stock collector pipe down to cat.
Reassemble in backwards order, no more ticks and less than $70 in parts.
If you are going to spend that kind of money I would just get a set of header's.
