Engine whines on start up
Sacramento, CA
when i first start the engine, there is a loud whining noise that goes away after the first 2-5 seconds. I want to say its from the belts and pullies, but ive sprayed them down with belt dresser and the whine is still there only on start up. btw i went mudding this morning and mud and water did get everywhere.
Power steering pump? Has it been cold and do you also sometimes hear a whine when turning at full lock?
Mine does the same, for me it's the power steering pump warming up. Goes away pretty quickly.
Mines makes a honking sound like someone stepped on a goose when it's below 40 farenheight. I never considered the power steering pump, but that a reasonable guess.
Most likely power steering pump. check fluid
To the OP; all the previously mentioned items;
belts, idler pulleys, power steering pump, alternator even. Would wash the mud off the belts and listen to see if any noise(s) change while the belts are wet. The most common cause IME is worn, loose, and/or non-OEM belts. If you do have anything other than a matched set of OEM alternator belts and the separate AC belt, I would replace them first IMO.
To BREATHED:
Oh my gosh!! you are the first person I have found who also has the goose in the dash!!
Gray,
I'll bet there are others out there. Maybe they just don't want to own up to such a funny sound.
Not to hijack, but the goose/wind instrument noise in my 80 seems to be coming from the left front dash, almost like it is inside the cabin; most often on light acceleration when over 70 degrees outside; a few times I have heard it on deceleration, but only when the ambient temps are under 50. I'm thinking brake booster??
Is you air conditioner on? could be the belts need tightned.
My two 80's both do that when they sit outside in the cold during winter.
My goose only honks on startup under 40 degrees. He doesn't like the cold.
If its only when you are cranking it may be one of the bearings in your starter. I would sound kind of like a "zzzzzzzing"
Mine has done it the last few days, Its been below 20deg. the last few nights, Its not during the cranking period, But just as it takes off, Mine also stops within a second or two, Mine again sounds like a power steering pump.
Bearings in the starter sounds like the ticket. It hasn't been giving me any electrical trouble, but I suppose a rebuild is in order. Good enough for me. Thanks!
Thanks for the enlightenment on the goose in a noose noise on cold mornings.
My wife suggested i get a goose permit incase it did it while i was around the game warden.
now i will aplly that money to a cruiser crap bottle opener.
seriously... thanks for the help. i was thinking my truck was sick.
Goose here too! Only when below 30 degrees F or so. Doesn't even last a second but it's a loud honk. Haven't traced it down since it doesn't last long and is only when it's cold.
maybe we should start a "who's got the cold goose honk" poll?
