Engine Running Problems (HESITATION) at Partial Throttle
I have a somewhat intermittent engine running problem. There are no vacuum leaks. I recently replaced the intake gaskets, TB gasket, and injector o-rings when I replaced the vacuum assist unit.
The problem started as a hesitation and loss of power at very light throttle conditions, but cleaned up as more throttle was input. Very recently (today), I started it up, backed out of my parking spot just fine, drove down the road a bit and the problem suddenly kicked in, but much worse. It suddenly had extremely poor power, a heavy hesitation, and once or twice a small "pop" from the exhaust, even when the throttle was at roughly 75%.
However, when going to wide open throttle, the problem ceased. Now it is intermittent whether it does it at only light throttles or up to 75% throttle.
To me, it doesn't seem like a spark issue, because a weak spark would get worse as more load is applied to the engine (higher throttle input). It's usually only doing it at low throttle inputs.
My question is, do the ecu's go bad in these cars? What sensors are prone to failure and/or cause these kinds of engine running problems?
Thanks for your help!!!
Seth
I have a 93 with a 1fz-fe
If the fuel pump relay was cutting in and out, wouldn't it be worse at wide open throttle, when fuel is most needed?
problems happened right after the work you did on the engine?
have you revisited your work to check yourself? maybe something simple got left off, or put on wrong?
The problem persisted even after i did the work; in other words, I had the problem since I recieved the car. I have double/tripple checked my work. No problems there. I thought that it was possibly a vacuum leak or a leaky fuel injector, but I had the fuel injectors ultrasonicly cleaned.
I'll check the fuel pump relay.
I wouldn't necessarily assume that.
How old are the plugs/wires/cap/rotor?
Oh, and: No engine codes??
Curtis
Nope, no engine codes. Plugs are new; however, the only available plugs at the time were autolites. It didn't aleviate the problem when i replaced them, but it didnt get better or worse either. Cap/rotor/wires i'm unsure as to how long those have been on there.
Personally, I'd replace 'em (with OEM, of course). I'm not saying that's definitely the problem, just that it's good maintenance/baselining anyway.
I'm actually chasing down a similar issue on my old Cressida. New plugs/wires/cap/rotor didn't solve the problem, but that's ok as they needed to be changed anyway. I'll probably do some fuel system checks next, like folks have suggested for you.
Good luck,
Curtis
Similar situation a while back after washing the engine bay.
At first it pointed to a wet dizzy, and then it became worse, could only drive by feathering the skinny pedal, found a sticky throttle cable. Fixed with a little lube and with the engine off throttling from the engine bay till everything smoothed out.
I suspect the sticky cable interfers with the TPS but I have been wrong before...
The FP relay has a low side and a high side. We have had reports where the low side was bad giving symptoms like yours. Landtank and Sumotoy have write-ups on how to do a temporary repair of the relay contacts. Try that first.
I have a 93 with a 1fz-fe. My question is, do the ecu's go bad in these cars?
The '93 is the only model year that we have any reports of bad ECUs but these are generally a *very* specific problem that you don't have since you have no codes.
If the FP relay is not the problem then look at the large hose going from the air filter canister to the intake. These tend to crack with age. Look at the bellows section on the underside of the tube.
-B-
-B-
These are very helpful suggestions. I'll check that out. I know the hose between the MAF sensor and the throttle body is old and hard, so that could cause false mass air flow readings to the PC. The fuel pump now makes sense to me, since it has a low and high side. I'll check that write up right away!
Thanks again!
Seth
Keeping in mind I probably top out at a solid:banana::banana:.....
I am having a similar problem in my 91. It was running fine, then it did not run at all. I tracked it down to the MAF sensor (which I likely screwed up myself). I made some adjustments within the MAF sensor and made sure all my connections were good, sealed it up and let her rip. It started right up and the only problem I have had since then is a hesitation at about 25%-60% throttle, then power after that. Seems to get better as it warms up a bit. My guess is that I adjusted something wrong in the MAF sensor when I was in there.
But again I am just a :banana::banana:. Good luck.
-B-
And if the large hose is cracked can you replaced at dealer?
Yes. Cruiserdan is probably the only Toyota dealer in the US that has these in stock. You can use duct tape to seal until he gets one to you down in El Paso.
-B-
-B-
Thanks I will check mine tomorrow, I just replaced my air filter and on my trip back from Mexico I got almost the same symptoms, so Iwill check this out before i replace my gas filter!
I replaced my gas filter, and the problem continue, then I replaced rotor, dist cap, spark plugs and ignition wires.
Problem solved!
-B-
Seth,
Did you solve this problem?
