same to you!
hey this is great info. I know it is silly but i kinda got lost as to what you were talking about and it started here:
Now the power steering mod can also be a bolt on mod. Since the fj40 has a lot of moving parts here, many will have to be changed out to get all the play out of it. You will have to ask yourself a question. What will it be used for and what size tires will I run? You can go to the Tech section and read about the different mods. Some have used a braket under the ps gearbox to change the geomety when using the toyto truck 2 wheel drive ps gear box. But the saginaw seems to be the most popular but it rquires a lot of cutting and welding. I think if you run bigger tires it handles better because it has less parts which means less play.
Or you can use a 79 steering shaft that came with the ps option. I believe this shaft is shorter when compared to a non ps steering shaft. I got a fj40 ps steering casing and used a 1985 4x4 toyota truck ps as a donor for the top part. Other years will work but I suggest getting a ps gear box where the high pressure and return line fittings match. The earlier ones had a smaller hole on the return side. I would stay away from those if you can. And if you are going rebuild your engine I suggest looking for a 79 or newer block. These have the oem ps holes and it will definetely be a bolt on mod. a fj60 powerssteering pump with 85 toyota truck high pressure line will work. I also used a fj60 return line cooler which I modified to fit the 40. If you don't need an engine rebuild you can get a braket for the ps made specificly for the 2f engine. Just like the "brakes" don't cut corners with mod.
I guess by now you know there are several mods out there that will let have power steering in your 40.
1. The toyota pickup: it uses a power steering gearbox out of 2wheel drive truck and pedestal to change the geometry to make it work. This would be the easiest one. However, They say it's not as strong and if you are running huge tires don't go this route. The pedestal can be made or bought on
ebay and is a bolt on mod for the most part.
2. The other setup is actually using fj40 powersteering casing and 85 4x4 toyota pickup powersteering box as a donor. You take the guts out of the 4x4 box and move it to the fj40 casing. Not sure if the fj40 casings are still available. Toyota parts are not cheap. And this would be the closest to being factory set up. From the steering wheel to the powersteering box there is a shaft that will have to be shortened. Rather then cut yours and weld, I would recomend buying the shortened shaft at the dealer. Again Toyota parts are not cheap and this can be a expansive mod but a bolt on mod.
3. The last I mentioned was the saginaw which uses a chevy truck powersteering box. This one is the most popular and has the least amount of moving parts but requres cutting and welding on the frame. Other powersteering boxes like the fj60, intanational, and other are used as well and also require just as much work.
I hope this helps. What year is your fj40?
My cruiser has around 300K on a rebuilt engine and is still running well. Compression is getting weak (90-100psi) but it doesn’t burn any noticeable amount of oil. I'm just now starting to consider re-ringing it and maybe getting a valve job, I think I’ll just put a turbo on it instead
Bottom end was balance when it was rebuilt in the late 70s by my father. I have trusted it to get me from A to B since I was 16 except when i break it wheeling of coarse. I have just recently got a POS DD to get me to and from work. Its not to say that I haven’t have to replace a few parts on the cruiser.
great to know. thanks guys. I forget these are CRUISERS!!!! I feelgreat now that when i get it to george's house and do to the compression he offered ( thanks so much by the way!!) if nothing goes wrong, its going to be sick knowing it should have no problems and run for a LONG time!
