engine module chips
Has anyone had any experience with engine chip upgrades. My understanding is that in the 97' landcruiser you cannot simply repalce the chip but must install a new module? Is there any significant change in engine performance?
First and foremost welcome:flipoff2:
I'm not sure anyone here has upgraded the chip module. People have upgraded to either supercharging or turbo charging with great results.
What kind of performance are looking for?
Gas milage, increase in horse power?
If you are looking to lift and add armor to a stock rig, gas milage and performance drops. These rigs aren't built for speed, I think the recommended top speed on the 80's is about 80 miles and hour. I have a lifted 80 with 315, front bumper, sliders, gear, family and I get get her up to a failrly 75mph no problem. To most of us here it's plenty! Chipping a stock rig "if possible" will not yield much bang for your buck in my opinion.
-Juan
I would be interested in what you find. OBDI cars take a chip upgrade-you would either reprogram the chip in your ECU or swap it with an upgraded performance chip. OBDII cars just flash reprogram the ECU unit-nothing is installed except software. OBDI units are very good for chip upgrades where as OBDII show less performance increase in most cars. I would guess that you could easily see a 10-18 percent HP increase on OBDI.
I don't know who makes them for these cars, but some performance shops might be able to reprogram yours based on testing your vehicle. Chips aren't cheap, though. You could see prices from $300-$900 depending on what route you go.
Post back if you find something.
Chris
Our ECU can not be programmed, well, I should say, there has never been any mention of anyone reprogramming a factory ECU (not that people haven't searched for a way to do it), you can only use a piggy back, or the chip Safari used with their Turbo, or try to DIY, AFAIK.
