ENGINE LIGHT COMES AND GOES
Missoula MT
I have a check engine light that comes on, then when I shut the truck off and turn it back on it goes away.
It has come on twice, each time was while accelerating. When it comes on it feels like the engine is sluggish. I haven't bin able to get it checked because its always turning off. What do you guys think?
The next time it comes on; shut off your engine, have your paperclip ready, and check the code through the diagnostic box on the passenger side firewall. That should enable you to retrieve the code.
if the light came on, it tossed a code. the codes are stored till cleared. i.e pulling the pos battery cable or pulling the efi fuse out for a few seconds.
do the paperclip, count the cel flashes.
So I did the paper clip trick in te1 and e1. The light flashes 5 times then it flashes 2 times. So is that a code 52?
Mine did this and found out one of the 02 sensors is about to come off . In other words rust ate the welds creating a leak. Did an exhaust rehab using OEM from cruiser yard .
