I have an engine I am trying to identify. If I recall it is an 1.5f out of an early 70's rig, but went to the casting numbers for clarity, and could not find a thread with answers.
Head casting is 60060 in left side on head top, then 0918 263
Here is what I found elsewhere
61031 is 2f head from 75-80.
61040 is 2f head from earlier 2f
81050 is 3f head, sometimes put on late year 2f engines.
This came from @FJ40Jim
If it is a 61030 to 61032, then it still has a 75-80 style head and uses the corresponding gasket set. If number is 61010, 61040 or higher, it is a closed chamber head and uses the 81-later 2F gasket set.
Engine casting number reading for date codes:
From the engine casting numbers on the side of engine it reads 20915
2 09 15 is in the Y MM DD format. So it is a 1972 september 15th casting I believe.
