Engine heat/valley plate leaks
GX Bob claims that the engine cover contains and retains excess heat that can contribute to coolant breakdown and valley plate leaks. Should we remove our covers?.......Thoughts
Retention slows heat loss but doesn't amplify the original heat source. I think Bob's process on this one is suspect.
Regardless of opinions I've had my engine cover off for about 40k miles. I came to the same conclusion as GX*Bob in that all that trapped heat will inevitably cause plastics, rubbers, and seals/gaskets to get compromised quicker over time.
The solution is a comparison using a TIC (thermal imaging camera) before and after doing the exact same test with as close to the same environmental conditions as possible. I could try and use ours from the department, assuming my chief would be ok with me borrowing it for the test. LOL
If there is much more heat trapped under the cover then I 100% think it could be a contributing factor. Not a direct cause but a contributing factor.
  • Like
Reactions: llm
This is pretty common in the Lexus community. Alot of people remove the cover for various reasons.
I have one of these: 12:1 Infrared Laser Thermometer - https://www.harborfreight.com/121-infrared-laser-thermometer-63985.html
It should work for just some spot temperatures.
Or you could strategically place a cheap thermocouple at the location and monitor it with a reliable meter.
  • Like
Reactions: r2m
