Engine cutting out
Ipswich, MA, North Dakota, Phoenix
Over the past week I've been having a problem with the engine on my 1995 '80 cutting out for no apparent reason. It began a week ago, after my wife picked me up at work (and just as the temp dove from 40 to around 5), on the way home the engine died. After sitting for 20 or 30 minutes, it restarted and ran fine. After a mile or two, the same thing happened. I coasted into a garage and left it. They diagnosed the coil as being bad, and replaced it ($95). I drove it for another week, then yesterday, same thing, engine died, and after a wait, restarted. Took it to the "stealership", and I guess once it restarted, they tested and couldn't find a problem. One of their older mechanics told them typically the EFI main relay fails when it gets heated up, so they replaced that. ($105). The truck barely got me home last night before once again, the engine cut out. :mad: :mad: Coasted into the parking lot. :censor: Now, I'm seriously concerned about the possibility of the truck failing me out in the boondocks. What can be the problem? It has a slight HG leak I suspect (trace of water in the oil), but runs great (WHEN it runs), the hoses going into the top of the valve cover show signs of oil around them (?), but other than that, it's in excellent condition. 170,000 miles. Any ideas? Thanks. :mad:
I suggest you take a close look at the engine wiring harness in the area where it passes by the EGR pipe at the back of the cylinder head.
I laughed a little at the $105 EFI relay replacement, but I suppose they were charging for diagnostic time as well. We've all been down this road at one time or another on one vehicle or another. All you can hope to do is learn from your's and other's mistakes.
91/92 FJ80s had the EFI relay issue while the FZJs have chaffed wiring harnesses. There's another part of the harness that passes through the firewall above the glovebox that has give people problems in the past. Also have a look at the fusible links off the positive terminal of the battery. They are prone to failure on older (FJ62/FJ80) trucks, but worth a looksee IMO.
