engine cuts out
Idaho Falls
Ok, so I purchased a 91 3FE FJ80 about two months ago and the engine died when I was driving it home from Salt Lake to Las Vegas... long story short the block was cracked and we couldn't rebuild so we replaced the motor with a used 3FE. Everything was running fine, but then it started having symptoms that I haven't experienced before.
The car starts fine, but it does idle high now 1100rpm on tach, and the real problem is that when it gets up to speed (55-70mph) it cruises fine for a while then the engine cuts out like a governor was engaged and it shudders, but then picks back up. It keeps doing this. The most inconvenient part is that it is a local mechanic shop in Fillmore, UT who has experience with 4Runners, but doesn't have significant experience with Land Cruisers. He has tried adjusting the throttle cable and the kick down cable, but that didn't help, only made the issue worse, so they replaced the Throttle Positioning Sensor and it helped a lot, but still didn't solve the problem. I am not sure if they were doing it correctly...
Any thoughts would be greatly appreciated.
Why were they adjusting the throttle and kickdown cables? Did you have any codes? Same question with the TPS. Did they test it? How does the engine respond when it's is acting up? Is there no throttle response? Or it just won't go above a certain speed? We need more information
I don't really know how to describe the way the engine is acting other than one I get to cruising speed the engine will intermittently act like a governer has kicked it. The engine doesn't die, but it acts like it's not getting fuel and disengages, I let off the accelerator pedal and then push back on the pedal and it runs fine for a minute then does the same thing thing again.
I think they were adjusting the cables because they thought it was a transmission shifting issue and it is idling above 1100rpm. I have since had enough of them doing nothing for me and have had it shipped to my new house near Idaho falls, ID. It is arriving this morning and will have some time to work on it starting this week.
How old is the inline fuel filter and the pump pre-filter in the tank? They have about 100K mile lifespan.
If your idle is high, then either the throttle cable is too tight and the throttle plate is not resting on the endstop, or your ISC valve is malfunctioning.
Idle speed is set by the ECU and ISC valve and the throttle cable should be adjusted by flooring the pedal in the cabin and adjusting the cable until the throttle plate is just touching the WOT endstop. When the pedal is released, there should be slack and the throttle plate should be resting on the idle endstop.
There is a "golden screw" on the front of the intake that sets the static idle air intake. It should be 1/4 to 3/4 of a turn out from fully seated. IOW, screw it in until it stops, then back it out 1/4 to 3/4 turn.
Remove the 15 amp EFI fuse in the underhood fuse box for about 10 minutes. This effectively "reboots" the ECU and allows it to relearn the sensors.
I went right to fuel filter in my head too.
If you haven't changed it, it's among the cheapest parts & at least you'll have ruled it out for a good few years of driving to come.
The vehicle has 186K miles, the newer engine has 120k miles, i am pretty sure there has been little no maintenance within the last 15k miles. I changed all the fluids and started the drive home to Vegas from SLC and the motor failed. I am also attaching an image of the mass airflow sensor area, the main hose is broken and the previous owner wrapped it in electrical tape and I need to know the part name/number so I can get a replacement. I have a video and will work on getting it converted to the right format so you can see what I am experiencing.
I couldn't get the video to upload, but I put it on YouTube.
finally got it figured out. the check engine light bulb was burnt out, so i had to replace that first off. then i cleared the codes and had it throw two new ones.
Code #1 was for the downstream #2 circuit O2 sensor
Code #2 was for Throttle Position Sensor
Funny thing was when I first started noticing the problem, I jumped right to that and had it replaced...turns out the shop who installed my new engine pinched the wiring harness underneath in the intake manifold when installing the manifold.
Removed the manifold, replaced all the gaskets, and put new injector orings and moved and repaired the wiring harness.
Problem solved.
i forgot to ask for photos before the Toyota dealership diagnosed and repaired
