Engine bogs and dies off Idle
Website
4cornerscruisers.com
Just picked up a 74 FJ40.
Would not start or run when I got it, so I changed the oil, battery, distributor cap, wires, plugs, rotor armature, and points. Also cleaned the carb and now it starts and idles well.
However, It will only start with starter fluid, and it bogs / ultimately dies with any pressure on the gas pedal.
Any advice or thoughts?
With engine off do you see a squirt of gas in the carb bore when accelerator is pumped?
/this\. If it will only start with spray, there is a higher likelihood of an accel pump issue.
I would also be curious what your vacuum reading is at idle.
Carb cleaner then pressurized air in all those little holes after disassembly. And safety glasses. After put a little fuel in the accelerator pump basin and pump the pump to see if a good squirt squirts. Assemble on rig after.
