Engine advice for a '96 80
Basalt, CO
Hey guys, I'm reaching out for your thoughts and also to vent a little.
Last summer I purchased a '96 80 that was in great condition (so it seemed). Low miles 140,000, turbo kit, bumpers, etc all work done by Slee Offroad. Paid top dollar for a rig that I thought was going to last a long time. Well I was wrong, in January the turbo went out. Finally got that pulled out and rebuilt, not a cheap fix. Sick of working on it out in the snow so I towed it to a shop for them to install turbo and put a new oil cooler on it as it was likely to contain metal from the old turbo. Well they pulled the cooler off and that space was full of this nasty greenish grey goop, full of metal grit. The shop says that the motor is on it's way out so not to re-install the turbo as it will kill it again. Sooo what to do?
Cut my losses and sell it as it?
Get the engine fixed up and run it? Tough to swallow putting 8-10,000 more into engine after spending so much for the rig already.
Other ideas?
What did Slee say when you contacted them about the turbo and when it was put on?
I'm sure they do not want their name and failure going around.
Is this rig your daily driver, or a secondary vehicle? Do you have the time and facilities to work on it?
yea, not sure how far you are from Slee, but i'd have had them working on it from the get-go...
from what others say about their service, if it was something they had a part of, they'd make it right... or at least give you a clear idea of where to go from there...
it's always a crapshoot buying someone else's project, turbo'd 80s aren't quite mainstream yet...
