Emergency Real Time Help Need Now!
Socal/ I.E.
:steer: Right now, I'm Driving in 100+ degree weather. I think my fan clutch went out, the belts are spinning but the fan is not. Worried about thermostat being bad, it was replaced 10,000 miles ago. The thermo needle has stayed in the middle of dash board. Could it be bad or is it just not showing that its hot? All hwy driving, so wind could be keeping it cool. Should I stop & pull over?
Need Help ASap!
Thanks.:wrench:
Is the water pump pulley rotating or is it locked up?
Not "spinning".
Can you free-wheel it with the engine off?
If you can't free-wheel it then that would indicate it is locked up. That is the opposite condition.
Yes you should worry if the fan is not operating correctly.
Are you driving while typing?
Yes, your gauge is probably correct, as far as it ever is. If it's in the middle it's not overheating. The engine may be hotter than normal though. What made you check the fan? The AC is probably overpressured from being too hot because there's less than optimal air flow through the condenser.
I'm amazed that the pulleys would be turning but the fan not at all. It usually will spin but not with full RPM when the clutch isn't engaged. I have to assume you don't understand Dan's question if you say the fan isn't spinning while the motor is running, but it doesn't freewheel when the engine is off. Please clarify.
OK, I got home. It stared getting hot as soon as I got off the free way. By the time I got here It was starting to boil over.
I belive I understand Dans question. The fan does not spin at all, both when the engin is running and when I try to spin by hand. The pully spins freely.
Closer than cracking a radiator up on top of the grapevine! At least I was at the rest area! No little ones with you I presume?
Sounds that way.
charles,
glad you made it home....nothing worse than driving and worrying the whole time...
