Emergency Brake Cable drop bracket?
TN
Where does the Emergency Brake Cable drop bracket go? Does it go under the little mount where the brake cable first gets to the frame?
Thanks
ERG80
Thanks
ERG80
Yes, the place where the emergency brake cable goes from the axle to the frame. I believe it's the same cross member the brake proportioning value is on.
Thanks man
What did you do to adjust your LSPV post lift? Did you just lower it on the bracket or did the 6in require more??
Thanks man
Now I think about it, I should have said goes from the frame to the axle. That makes a little more sense.
Took the one I got from Slee off. I felt the ebrake cable was to tight. Works fine without one installed.
I have 5.5 inch Zeal coils installed.
Cheers,
LandCrusher80
What about your LSPV? Did it require more than just dropping it on the bracket?
Cheers,
LandCrusher80
