Emergency Brake Adjustment
Germantown MD
I have adjusted my e-brake 2 times now and after a couple of days it goes right back to where it was before.
I have to pull it up way too high to get it to hold the cruiser on even a flat surface, not to mention an incline.
Am I doing something wrong? I am adjusting at the star shaped adjustment behind the rear rotor hat.
The star shaped adjuster can jiggle itself loose over time. I didn't believe it could move at first, but after opening up my e-brake for the third time, I confirmed it.
When you move the star adjuster with the screwdriver (the drum is still installed), do you get good, positive-feeling clicks? The star adjuster rides against a spring (that's what makes the audible clicks). I ended up shortening the spring to make it more taught in order to hold the star adjuster in place.
The e-brakes are definitely a pain to keep adjusted.
Doing something wrong? Maybe not wrong, but not complete...
Reading through the FSM, to adjust the parking brake you need to first make sure that the rear
brake shoe clearance has been adjusted properly, then adjust the bellcrank, and then adjust the handle inside.
If you do a search on parking brake or similar keywords and userid Poser, he had a good write up on a complete rebuild of the parking brake system that might help you.
Me, I just adjusted the handle in the cab for now while I had the console out :)
I checked the FSM. How many clicks are you getting? FSM says 7-9 is factory spec. If you are not in that range it says to "adjust parking brake" which it sounds like you have done? How did you adjust it? It also says that before you do that to check the "rear brake shoe clearance". Standard clearance is less than 0.35 mm. I would recommend getting a helper to sit in the cab (engine off and in P) and work the e-lever while you you get under the rear axle and watch the cable action. See if the cable is moving freely or the springs at the dust shield are siezed up with corrosion. The rubber boot at the the bell crank may be corroded as well. You can make a bell crank adjustment there if I recall correctly, but the FSM hits it on these pages. (BR1-27) Good luck and please post back what you find out.
I've found that just adjusting the star adjuster is fine. This is one that I threw the FSM procedure out. Here's how I did it:
  1. Chock the front wheels, jack up and place the rear axle on jack stands.
  2. Remove the rear wheels.
  3. Adjust the star on the PS with a flat head screw driver until the rotor will no longer turn.
  4. Back off the adjustment slightly until you are able to turn the rotor, but have a slight resistance.
  5. Repeat steps 3&4 on the DS side.
  6. Pull the hand brake tight several times and release.
  7. Check the the rotors again and adjust as necessary.
  8. Yer dun.
This will leave a slight contact on the drums, which will quickly wear appropriately on the shoe, leaving a nice, positive e-brake.
Raventai's write up is very helpful to follow.
