Hey rebuilt my rear actuator this past weekend and it appears I was missing the little vent plug for the small actuator vent hose. I have been looking all over for a replacement and can't find the small ones just the larger ones for the axle. Anyone out there have a part number or suitable replacement? Thanks
Well never mind I actually found the little cap sitting right on top of the frame rail. It appears it is nothing fancy just a rubber plug with a hole in it.. I extended it up I to the rear cubby where the jack is..
Question about these vent tubes. While rebuilding my birfs yesterday, I noticed that the hose isn't very long and was thinking in case of a water crossing that water could make it's way in? Is that cap a one way check valve or something?
This is what I did. I did the front diff when I rebuilt the font axle ten years ago. I pulled the rubber mat out of the stock check valve and put it on top of the cheap fuel filter.
I didn't have enough hose to do much with the rear so I cleaned the check valve and raised it to the top of the body pan. I had always planned to reroute the rear, but never got around to it. I just changed the rear diff oil and got some oil puking out after a short drive. So I finally rerouted the rear, added a fuel filter and modified the check valve. I hope this buys me some time. I'm not excited to rebuild the rear axles seals in this heat.
