first, I don't like working on the trucks wiring. It makes me unhappy. No opportunity to use hammers, and plenty of opportunities to cut/burn/poke my fingers as I try to cut/crimp/heatshrink stuff into the space within the dash.
But
Having said that, I did finally spend a few hours yesterday attacking some wiring issues behind the instrument cluster.
I've got extra issues there because when they did the engine swap (and the dash swap) they didn't always do everything the very very best way. For instance: my oil pressure gauge didn't work. There was a red wire connected to the pressure sender, that went from the DS of the motor, to near the fusebox on the DS, across the front of the motor (in split loom, with many other wires), down to near the alt, then into the firewall, presumably across the dashboard, to the instrument cluster. At some point, presumably, it was spliced to a gray, shielded wire, that I suspect might be the wire used on the EFI for a gasser.
It only took a few minutes to route a wire from the inst cluster, through the firewall (under the brake booster) and to the oil pressure sender. Now it works.
Same could be said for the H2O temp sender. That was even easier to re-route because I didn't bother to take the time to trace the old wire.... I just snipped it and added a new one.
Also, whoever installed the hd-t into my truck appears to have had mostly blue, 14ga wire sitting around as that is what was used to connect most of the connections. Makes it slow work to figure out what wire does what!
So here is the tech part: if you are trying to wire your ARB such that it illuminates the diff lock lights in the dash, it is dead easy.
You want connector D on the cluster. Wire D7 does the rear locker light, wire D6 does the front locker light. I also used D3 and D4 (a circuit) to make the AT/P light come on when the compressor is on. Since I don't have an auto tranny, this shouldn't be too confusing to me.... the rest of you might find the glow light to be a better choice (but I hope to use that for a glow system if/when I ever get said glo fixed).
The terminals are really easy to pop out of the plastic coupler, and you can move them around if needed. For example: D6 and D7 were empty on my truck, but there are other connnectors that don't do anything at all, so I just stole one of those, and spliced the wires to them so that now I can illuminate the lights I want.
Another note: next time I do work on the cluster, step 1 will be to remove the steering wheel. Overkill? Perhaps. But if you have a puller (I do) then pulling the steering wheel off only take an extra minute or two, and it gives you so much more space in which to work that it is really worth it.
Another thing I'll do on future cruisers: find a good spot to put a ground wire, then add a bolt with space for ring terminals. I now have 3 or 4 ground wires spliced in for no good reason other than not looking ahead far enough to realize that I would be adding more grounds to other things (like switches or LEDs or just repairing grounds).
Speaking of grounds: Black isn't necessarily a ground on the dash wiring. In some cases, black (with blue strip) is always hot.
Here is the diagram that matches my instruments (hd-t, non-USA). It is page BE-50 in the FSM.
Long day, and very frustrating. For some reason I (and my crimper?) have trouble making solid connections on such small wires. If I'm not very careful, the wires tend to slip to one side of the barrel, then they pull apart when I'm trying to get stuff re-assembled. That part isn't fun.
So I ended up redoing 4 joints while the sun was going down, in a vain attempt at finishing the job before, well, today!
But
