Electrical woes
Kamloops, BC Canada
Website
www.shopraddcruisers.ca
Funny thing today, been driving the HZJ45 for some time, today after new rad went in I kept the hood open while I warmed the engine up.
Noticed smoke coming from a connector, it was hot and starting to cook the wire and melt the connector.
Looking for some insight, thinking prolly just bad connection.
Thanks
Rob
Coolerman said:
Could be a corroded connection causing too much resistance but i would be looking down stream for a pinched wire somewhere.
Thanks for the insight, funny thing again, after charging the batteries and running it, no more problem.
Electrical gremlins, thier the worst.........
Now you see them now you dont...
Radd;
Check for fuse link problems; like shorts; twisted wire (s).
Maybe some pics of problem area would be a good idea.
dfmorse said:
Radd;
Forgot to mention I pulled the speedo and did find one of the alternator wires into the Amp meter was loose.
Rob
This indicates that the circuit is sinking too much current, because of an excessive load or a short; just the opposite of what would happen with a corroded connection. Most of the circuits are fused to protect them from this kind of experience, so dig in and find out what is wrong before you burn something up.
since heat = (current)^2 * Resistance, it could be either too much resistance at the connector or too much current. With a corrodec connection, the current will go down, but the voltage drop starts to occur in the connector which will cause heat at that point.
