I need a bit more guidance on my short problem.
Problem: Turn Signal/Regulator fuse is shorted. I eliminated the fuse box and the turn signals as the culprit. (tested separately) Line to the regulator was shorted... or the regulator itself was shorted.
When I tested the fuse, it shorted whether the alternator was plugged in or not.
Just replaced the regulator. Now, it shorts with the alternator plugged in, but not when I unplug it. I think that means that I did have a problem at the regulator, and fixed that, but now have another short somewhere downline of the alternator.
Looking at the wiring diagram, there is a dotted line "E" from the regulator to the alternator. I don't know what that does or whether that could be causing the problem.
The other line out of the alternator goes back to the fuse box with a cut off going to the Ammeter and the ignition switch. I don't have an Ammeter hooked up. Came that way.
Don't know if this helps, but this short occured while driving. It's not something that has happened intermittently...
Any ideas?
Thanks,
Any ideas?
Thanks,
