Electrical Questions/Issue
Tacoma, WA
So I searched around and couldn't find an answer to a couple of questions I have. I'm sure someone on here will know something or at least have an educated guess.
1st question: Does the voltmeter in the dash normally bob up and down when the turn signal is engaged? See video
I'm wondering if this is a sign that the alternator is ready to go or if this is normal.
My next question: What the hell is causing my temp gauge to peg and bounce around when accelerating or going over bumps? Coincidentally I noticed it just after I drove through a couple of big puddles. I haven't tested it with the motor off yet. Video is not working so I'll try to take another.
Thanks for your input!
Video is private...
Voltmeter bouncing might indicate a weak ground for the instrument cluster.
Temp gauge bouncing is most likely a bad connection at the sender. It's up behind your A/C compressor, into the block. Two wires go to it, one is ground, other is sender.
When my alternator went out, the dash gauges started acting crazy too. Drive on down to Autozoo or the likes and have them test your charging system for free.
Video is public now. Thanks for the heads up.
In reference to the temp gauge pegging: I forgot to mention I have a Scangauge II installed and the temp readings on it are normal. Does this mean the problem is inside the instrument cluster and not the wiring from the sensor? I would think the SG would show a bad reading too if it were the wiring from the sensor or the sensor itself.
Thanks for the feedback. Sounds like it's the sending unit for the gauge and not the temp sensor to ECU since the scangauge is working. I won't worry too much about it for now. I am going to re-wrap the wiring harness on the top of the engine with heat tape because the old wrap is worn through.
I had the same issue last year. My temp gauge, would move erratically, lucky we have a gauge tester here at work which has a variable knob so you can see if by rotating the knob your gauge would slowly follow. Mine tested fine, the problem ended up as bad wires coming from the sender all the way to the harness on top of the engine to the cluster. I had to run new wires from the sender to the cluster.
ever since that I did the heat tape and I never had that problem again.
btw, I have the ultra gauge too, so I know its not my actual temp rising, coz it shows fine on the ultragauge.
