Electrical Problems - Dash Lights and Cruise Control/Blinker
Boulder, CO / Abq, NM
I have a couple electrical problems that I can't figure out.
First is my instrument back light doesn't come on with the lights. All the other lights on the panel light up, like the blinker, cruise, brights, everything except the back light. This is also the same over on the Vent control panel, all the lights come on when the buttons are pressed (A/C, vent control, etc.) except the back light that lights them up.
This happened the morning after I took off all that faux wood paneling so I was working and peeling off the glue around all those places... don't know if that was the cause or not. Also, the fuse for the Dash is still working.
The second problem that is more annoying rather than needed to be fixed is when the cruise control is set, whenever I put on my blinker, the cruise control is cancelled. I believe there is a short somewhere in the column, but haven't gone looking for it yet.
Update: I figured out the dash illumination, the fuse is for the rear lights and not the dash.
I still don't know what's up with my cruise control / blinker problem.
Do you have LED tail lights? Some of the LED tail lights will cause issues with the cruise control. Do a search with LED and cruise and you should get some hits.
Tom
I do have LED brake lights, the turn signal and back up are still bulb. I tried searching those terms and similar but no luck with hits.
I figured out the dash illumination problem since it is tied in with the rear light fuse and not the dash fuse as I had first thought, the turn signal disengaging the cruise I still haven't found anything.
I don't have a schematic so this is a WAG: If the cruise is cancelled by the electrical signal from the brake lights, it is possible that the blinker signal is feeding back to the brake line if one of the rear lamp housings is poorly grounded.
That could be very possible. Are the lamp housings just grounded using the screw to hold it in?
