OK, I'll give it a shot...
when running, the amp meter sits where it used to when it was running right, justbelow the middle of the gauge
Mmmmm, nope, not good - this means when your engine is running you are DIScharging the battery (- Amps from battery) This either means your alternator is not putting anything out, or your truck is drawing MORE than your alternator alone can put out and has to draw the rest from the battery. OR, there is a mistake in the connection between the alternator, ammeter and battery.
With the ignition OFF, turn your headlights ON - which way does your ammeter go? (+ or -?) it SHOULD go -. If it goes + something is hooked up wrong. Any LOAD should make the meter go -, any source should make the meter go + (alternator is a source) Your ammeter measures the NET charge of the system. If you are drawing 15A to power your ignition system and headlights, and your alternator is putting out 15A, your net charge is 0A - so your meter stays in the center. If you are drawing more than you can put out you end up with a - reading. After a start, your alternator is putting out more than you are using, to make up for the charge used to start. Therefore your output is higher than your load, so you get a + reading.
when i try to start it, when it is dead, it jumps to about the middle of the gauge
THIS to me says the meter is hooked up WRONG. The meter should drop ALL THE WAY DOWN when cranking, for two reasons - #1, your alternator is putting out NOTHING while you crank. #2 your starter draws WAY more current than your alternator can put out, so even if somehow it was putting out there is NO WAY it could keep up with the amp draw of the starter.
If I had to make a guess, I would say that there is something wrong with your voltage regulator, or your alternator exictation circuit / field wiring.
Measuring the voltage at the alternator B+ post (red lead here, black lead on battery (- post) will tell you if your alternator is putting out. As mentioned, it should be above 14V when the truck is running - if it is not, your alternator is NOT charging.
You may have had the alternator tested - did they test it in the truck or bench test it? If it was bench tested then they did not use your trucks wiring to turn it on, so it would likely be the wiring in the truck that is causing it not to turn on.
You should also check all your conntections, bad/dirty connections can make a HUGE difference.
A little trick for you....
When you have the truck running, with 14 or more volts at the alternator output post, set your meter to DC volts... Put one lead on the alternator B+ post and the other lead on the Battery + post (not a typo) If all your connections are good, you should get a reading of 0 Volts. If you get a reading of a few volts -say 2 or 3... you have a bad connection. This is what is known as VOLTAGE DROP. You can repeat the same process from your Engine Block to the battery (-post) you should read 0Volts here as well. This would also give you a reading of 14V at the alternator, but lower at the battery. If the charge voltage that reaches the battery, is LOWER than the battery nominal voltage (due to voltage drop over bad connections), it will NOT charge the battery even though it is putting out.
So... uh... did that make any sense to you?
Any thoughts?/corrections (Pinhead?)
Hope that helps you find the problem. Many people are afraid of electrical, and it can be a real bitch to troubleshoot, but as long as you can get your head around some basic stuff, it is much easier to work with!
HTH
Bruce
