Electrical joy. Just kidding.
America
Hello friendly FJ enthusiasts, I am in the process of pulling out old wiring from my ‘74 FJ40.
Got a economical question for the group:
I picked up a Painless harness; and will sub contract it out to an acquaintance, to have a helping hand guide me through the install.
Or I can take it to a shop.
My question is, what would be a fair ‘labor’ cost for a private hired hand / VS. a shop ?
Thanks for any insight.
what is wrong with the old harness?
is there anything not stock on the rig?
painless is far from it, or so I've heard
install cost could be between $500-$1500, there are way too many variables.
It had blade fuses, headlights & rear lights were not operating, and I didn’t feel comfortable with the PO’s workmanship in general.
It has a ‘77 350 !
The
Do you want the current connectors attached with butt connectors or do you want the connectors re-pinned? Big difference in labor, appearance, and function.
That 1974 FJ40 harness looks to be in good shape?
Unless you really like scratching your head trying to figure out how to interface Toyota Hazard/Turn/Wiper/Headlight wiring based on switching ground, to a harness built for rat rods and based on switching hot, I would look into having your existing harness refurbished so that it works and just plugs into all your existing dash stuff.
Your 1974 FJ40 harness can be refurbished if the following conditions are true:
The harness has not suffered a vehicle fire.
The harness has not had a major meltdown in the primary charging circuit. (Very difficult to repair that amount of damage)
The harness is not covered in heavy baked on grease. (Those harnesses take too much time to clean)
The harness has not been spray painted or under coated. (Those harnesses take too much time to clean)
The harness should have most of it's connectors intact.
If your harness meets all those specs and you are not in a big hurry, send me a PM.
Id rather leave the current connectors in place, and just move forward with what the fresh kit supplied.
Hi Coolerman; going through your checklist, the current wiring was unprotected and road grime coated.
The Plugs and relays seem to be in fine order. Thanks for checking in with a rookie.
Well I was just contemplating going with a painless harness for mine. PO used scotchlocks and crappy butt connectors to cobble up a lot of the wiring. I cut out all of that and then stripped the tape of the main harness and found some small melted wires individually wrapped in tape. I decided to use the existing harness instead of the painless and properly repaired the melted wires. After reading the above comments, I guess I made the right choice. My 75 is outfitted with a 350 and a new Flaming River steering column. I am using combined rear stop/turn function LED taillights and factory front turn signals. I am running the factory gauge cluster along with Auto Meter gauges, factory switches (Lights/heater/wiper etc), and a slew of aftermarket accessories. Tomorrow, I get to try to figure out how to properly wire everything together. I just wish I had a better wiring diagram. All I have is a Chilton's manual and it's not a very good diagram. Is there anything out there better for a diagram? Please share. I could use it tomorrow.
