ELectrical issue
queensland
Don't know if it belongs in this forum, but its on my 80 so its close enough :)
I installed an aux fuse box in the cabin the other day..
Now im having a drama with getting power to it..
The battery has 12v, either side of the circuit breaker has 12v, tested resistance of the wiring, that all came up with 0.02ohms which is all good and my common earth for the fuse box uses a factory earth in the cab, but at the actual fuse box it only has between 4-6v, my next step is to get some heavier duty cable, it has some dual core at he moment, diamter of the wire about 3mm so should be enough for the current and load of the job. Also i checked it when i first installed and had 12v, checked it again 10mins later and found the low voltage issue.
Any help or suggestions are appreciated :)
"the actual fuse box it only has between 4-6v"
What are you measuring between?
Typically, aux panels should have a dedicated ground back to the battery negative terminal, the same way your +12 feeds are dedicated.
I agree with Jonheld, i would use a dedicated ground for your fuse box. It seems that most of the electrical problems i have faced on new cars , more then 80% of them could be traced to bad grounds.
Yeah that was it, sent another earth wire direct to the battery, and shes going hard now, cheers guys! :)
That to me points out that the existing factory grounds may not be 100% and could potentially cause some other issues. In your picture where you attached the original ground would be one point I would address followed by the battery to body ground in the engine bay.
