Electrical Issue: I think
Lake Jackson, TX
So, I've known for a while now that I need to replace the switch panel on the drivers door for the windows and locks. That's been acting up. However, today, everything quit completely. None of the windows on any of the doors worked (fortunately they are all up.) and neither the driver's side, nor the passenger side could lock the door electronically. My immediate thought was: I must have blown a fuse or something. But I opened up the fuse box, and couldn't find any fuse for the windows/locks or anything similar to that. So I looked under the bonnet and couldn't find anything there either.
Has anyone else experienced this issue?
In your fuse box under the dash is a square shaped fuse, probably called a fusible link.
On mine, that "fuse" was damaged, and some PO idiot just bent it back together (no longer a fuse, just a short). I was checking fuses and pulled it and replaced it, and my power windows quit working. Of course that's when it starts raining.
Another thing often overlooked is the window lockout switch on that door panel... Just sayin'... Probably won't cause the door locks to be inop however.
Yah, I use that power lock switch a lot. (I have a dog who figured out how to roll down the back windows.) So I checked that. But the locking was the thing that let me know something was off.
That part is named 30A FL POWER. It's in the lower RH corner of your Instrument Panel Left fuse block (your left knee).
It feeds your door lock control relay, the power window power relay, which then feed the Power Window Master Switch.
If it's blown or questionable, you could swap it temporarily with the 40A FL HEATER right next to it. Beware, if it blew from a short, it may toast the heater fuse as well. Be careful!
That 30 amp power fuse feeds door locks, sunroof, and windows. If the windows are the only thing not working, then it can't be the fuse.
However, all window control goes through the driver's door switch panel. First step would be to re-seat the connector on the panel, then check the connector on the door harness that feeds through the body grommet.
