I rebuilt my 1fzfe motor last year and it has run fine other then a little idle issues here and there. I planned on revisiting the idle and timing today. Recently I found I was missing a CEL bulb another gift from PO....probably to help sell the damn thing. I replaced the bulb to find a cel after driving short distance. clears itself when engine is cold. not on at startup...get down the street a mile and its on.
Did the OBDI (1994) jumper and got code 25 and 55. I ordered both the the O2 sensors put them in and now I have code 28 and 55.
I had to fix a wire to one of the O2 sensors when I rebuilt the motor (the one that goes right over the transmission. I also had to fix the number 1 knock sensor wire back then. SO this seems like its not a coincidence that they are both throwing codes. I may not have fixed the wires correctly or I did and they wiggled loose or heated or who knows......So the question is, can someone tell me how to check these with my shiny new digital multimeter. I am not familiar with these tools or electrical but plan on taking the whole day to figure it out if need be. Is there a voltage or something they should have running through them? key on, engine on, off etc? I am ignorant with this stuff but capable of following directives if someones bored enough and willing to throw a dog a bone.
(I never did much mechanic work before the cruiser, after full rebuild I'm confident I can fix anything in it with a little guidance)
I will order a new sensor if I can check to make sure its not a electrical issue. I cant see the locations that I fixed the wires otherwise I would know, I completely taped and protected the harness while motor was out. Also, on the 94 I'm not sure if I have 1 or 2 knock sensors and which one 55 is?
Thanks a million
Thanks a million
