electrical help needed
Iowa
I finally picked up another 40 this week! :D
It's a mostly stock 1973. I'm trying to get some gremlins out of the electrical system (which looks stock and unmolested) and I was hoping someone might have a suggestion before I start tracing every wire.
Any ideas on what would cause this scenario would be appreciated:
Turn signals work front and back with headlights OFF
Turn signals only work in rear (and seem weak) with headlights ON
Right rear brake light not functioning.
License plate light not functioning.
Without a wiring diagram on hand yet I'm at a loss as to where I should start hunting. Bulbs tested and they are all good. Thanks!
Check the grounds at each light. They are chassis grounded.. The headlight thing is throwing me off though.
looking at the diagram I see that the front turn signals are chassis grounded and the rear ground via the harness. License plate light is chassis ground. My dad had a towing harness installed on his 40 long time ago. Whomever did it screwed up the wiring pretty good. I ended up removing it and re wiring the harness. Does your rig have a towing plug? Maybe a place to start.
try this link. It should be pretty much the same .I have this diagram and I found it to be pretty good and helpful Don't trust the wire colors too much though. My factory harness had the same color wires in the entire back end. Almost like they used whatever they had the most of that day. http://www.yankeetoys.org/documents/wiring_diagram_78_fj40.pdf
btw. It was in the technical links section
Thanks for the reply. I'll start with the grounds. The wiring in the back does have an old towing harness spliced in. I'll try to bypass that too and see if it helps. Thanks for the link to the diagram as well.
:cheers:
There are lots of possible problems that could account for these symptoms, but they basically are all bad connections somewhere between the fuse block and switch and ground. The front turn problem sounds like a bad ground because it changes in response to the headlights, suggesting that the turn signals and headlights are trying to use the same ground through the front bib.
Ground problems are the most common and you can easily diagonse them by running a test ground wire from the battery - to the bulb housing to see if it makes it work. Sometimes just running a new ground wire is easier than fixing the original sheet metal ground path.
There is a schematic diagram for a 71 in tech links and it will be close.
Thanks for the help. It was a combination of bad grounds in the tail lights and crossed wires in the front turn signals. The turn signal relay is an aftermarket part, so I'm going to replace it with the Toyota part if CDan has it. Also, the tail lights are rusted through inside and the wires had been spliced into poorly for a towing harness. I removed the extraneous wires for the harness, cut off any damaged wire connectors and replaced all the bullet connectors. I still need to make good grounds for the rear side marker lights to work (missing the tiny 7mm nuts) but everything else is working as it should.
Thanks again! :D
