My '97 LX450 has been having idling problems for awhile now. I'll skip all the things I've checked (vacuum hoses, EGR, exhaust, main air intake hose - all good). The truck started throwing codes relating to the throttle position sensor, P0120, P0510. I purchased a new TPS and installed it, cleared the codes, and drove it this weekend. The rough idle is gone, but it idles high now, and while their is one more system that needs to reset and no CEL light on yet, there is a temporary code of P0510 again in the system.
I have a '96 EWD and '97 FSM. For a P0510 code the FSM says that with the key turned to the 'on' position I should be reading 9-14V between terminals E2 and IDL of the wiring harness at the TPS. But there's nothing. To check if the wiring is bad (I've already opened the harness at the EGR - didn't find anything, and inside near the glove box also no problems) I decided to measure the voltage coming out of the ESM. The FSM shows which terminals at the ECM are the E2 and IDL (ground side), and the EWD shows the same. So, I unplugged the E5 harness at the ECM and checked pin 11 (+) and pin 9 (-) and there's nothing. Pin 1 is the VCC, it was supposed to have 5 V, and it did.
So I'm inclined to believe that my only diagnosis here is that the ECM is bad since it's not putting out any voltage at the E5 connector, pin 11 with the key on - and I am really hoping someone can tell me I'm wrong (@TrickyT )!
