Electric window wiring
Ibiza
Hey all. so a few weeks back I finally got round to attacking the left rear electric window that's never worked on the car since I got it. my little boy is now old enough to be able to have a working window, so thought I'd sort it for him.
I pulled the old mechanism out and it was totally kaput, motor siezed/jammed with years old rust and crud, freeing it up showed no signs of life on putting juice across it, so I binned it and ordered an ebay replacement mechanism.
today it arrived, so excitedly I tested it, works perfectly in both directions off the car, but is dead as a Dodo when operated via the switches, both on the door itself, or from the master in my door.
The (red) feed lead into the motor/mechanism in the rear door has power there. do people think I now also have 2 switches both faulty at the same time, or is there something else common I might be missing here?
(I am away from home without my Manual to delve into wiring diagrams currently)
I recently discovered that a back window will not respond to the master switch (driver's) if the local switch (back) is removed. Perhaps only your local switch is faulty. You could try replacing it with the switch from the other side to help narrow down the problem. Hope that helps.
I had this problem.
Drivers side kick panel in the A pillr. Pull out the harnesses, unplug and replug 2-3 times and put in some dielectric grease to help seal for future issues. The sunroof drains and leaks through there get the harness wet and corrodes the connectors.
I did the SAME thing you did and this recovered my window operation.
I also ended up eventually replacing my master switch with a Switch Doctor version for $45. It's been good for 3+ years now.
mucho gracias for the info mi amigos
For anybody with similar issues, this was "t3h correct" in this instance ..swapping the switch with the other rear one has it working fine, so the jammed motor must have taken the switch out with it, either at the time the motor died, or sometime since.
thanks again chaps.
edit. I just WD40d the faulty one to within an inch of it's life, without taking it apart, operated it a couple dozen times, and put it back, it's working again for the moment.
They aren't too difficult to disassemble and clean the contacts.. just pay attention for small parts when you open it up. IIRC You can also swap the two contact rockers inside that will give you fresh surfaces.
When I took apart my switches, I discovered that the copper rocker inside was flattened out from years of mashing the buttons. The only onethat was close was the left rear, so I bent the rest to match that one and they all worked better.
