Electric Fuel Pump or not
Bonita, Tx
Anyone out there using an electric fuel pump on a 2F?
FJ that I just got has a new one on it, but not sure if it is
the way to go. It's a Mr Gasket 12s and am already having
problems with it moving fuel to the carb.
my fj55 has one, it seems to work fine, if I actaully drove it I would swap back to the mechanical one. I don't see any benifit to the electical FP
Does the one on your 55 have any type of check valve on it to prevent
backflow into the tank? Think thats where part of my problem is.
Perhaps you should replace with OEM. I just bought a 76 that looks to have the original fuel pump. It works great, except there may be a small leak because I can detect a fuel smell coming from its vicinity. No drips though. OEM is around $90 I believe.
Running a fuel pump w/backflow protection on an 82' FJ40. Works great. My engine likes to crush the mechanical kind, regardless of the gasket or spacing. The best is, the mechanical one took many turns of the engine to get the vehicle primed for a start. With the electric one, my baby fires to life quickly.
Pump is definitely mounted too high....I can hear fuel draining back into the tank when I shut the key off. Gonna fix that tonite.
It's important that you don't run the electric pump through the old mechanical. Eventually, the diaphram will rupture and you will fill your engine with fuel and hydrolock it. Other than that, the reliablity isn't as good, in my experience, and the noise can be annoying. It is far easier to change when it dies on the road.
I have a $40 electric from napa mounted high with check valve.
It works, is not loud (mount to engine or frame, not body).
A new mechanical is on my list of to-do's. The old one lasted an even 30 years, I don't trust this electric for another 6 months.
Another nice benefit of the mechanical is that when running your engine with no accessories, there is virtually zero current draw (ignition system is very low current). - If your alternator fails, you can drive many many miles on just the battery.
I put an electric on my (mostly) 75 FJ40 because my oil started to thin out and got a quart or so high. I suspected a leaky diaphragm, so I went to an electric one due to the Toy being my backup car and sitting alot. The electric fills the carb without cranking it over till the battery croaks. I mounted the thing on the framerail on the passenger side and used a GM big block pump block off plate to cover the hole from the mechanical pump. It was a little noisy, so I wrapped it with rubber under the hold down clamp. I installes a fuel filter before the pump and a clear one after it since i have heard they can shed metal into the fuel when they fail. I am running power to the pump from an extra terminal on the relay I have powering up the HEI I installed
That actually brings up another potential problem with an electric. If you roll bad enough that you are injured and can't shut off the vehicle, the engine might stop for a variety of reasons, but your fuel pump will keep pumping and could make your situation a lot worse. Few of us, (myself included on my TBI) add a oil pressure or impact shut off switch.
I think tha possibilty that it would be a real problem is rather remote, but the car companies all have to include an automatic shut off, so I thought I'd toss that out there.
Gumby is right about the keeps pumping thing. I put an extra kill switch on my dash, but it still assumes you can reach it. My truck is not in good enough shape to do serious, may roll over off roading, but it could be a real concern. There are auto shutoff switches, like he mentioned.
You have the incorrect spacer or pump on this engine.
In Texas my FI goes thru electric pumps like Junks mama thru Depends if you go electric and go into the boonies carry a spare
Another thought - if you truck sits alot couldn't a elec. pump be used as a primer for the mech. pump? I have an old power wagon set up like that and it works sweet. the primer pump is at the tank before the OE pump and is pressue sensitive so it slows as the pressure at the carb increases. To prime ijust pull the switch on the dash and wait 'til I hear the pump slow and then shut it off and bam fires every time. just a thought...
Eactly how mine is set up--electric pump before the mechanical pump. I only use the electircal as a back up system but it is great if I got to pump up the fuel before I crank, crank, crank. I also have duel tanks with an electric selector valve and I use an electic pump to transfer fuel from the rear tank to the front or to a gas can if I got to mow the lawn.
Similar setup as Paul, only I use an airplane like selector to chose which tank the pump is using. Great setup. Have had the same pump for about 5 years now without any problems. What POS electric pump is everyone using?
