Electric fuel pump conversion???
Ball Ground, GA
I think my fuel pump is going bad on my 80 and the cheapest replacement that I have found is about $250.
I was thinking about putting in an inline fuel pump.
Any one done it? Pros/cons, any better less costly suggestions???
you talk to cdan? how about one from a truck someones parting out ?
No I haven't talked to cdan. I will look him up.
Don't know any one parting out an 80.
Check out IRBIS in the vendors section. The last I knew he had a half dozen trucks being selectively dismantled. I've bought several parts and pieces from him and been very happy with the results.
Now, how certain are you that it is the fuel pump? Have you tested it?
Have you tested the relay? Fuel pressure at the rail? Fuel filter? (Yes, there is a fuel filter and yes it is a pain to change. It is located above the PHH and under the intake.)
I have replaced the fuel filter but.....how do I test the relay/fuel pressure?
Relays are tested by replacement. There is a relay inside a pocket on the drivers side fender well near the firewall. It controls the fuel system.
For testing the pressure, you'll need a pressure gauge and the hardware to insert it into the line. I used a line splice and a T. Since this involves cutting, tapping and re-splicing a pressurized fuel line, you might want to have someone give you a hand with it.
What exactly are the symptoms that your truck is experiencing? Does it run at all?
About 80% of the time it runs like a champ!!! Then other times it sputters like it's outah gas but NEVER dies! It will always idle and start no problem! I have looked inside the tank and eveything looks great!
The fuel relay switches between full battery voltage and reduced voltage via the fuel pump resistor based on throttle position, I have seen a lot more complaints about the relay here than the pump itself.
new one is $100
you can take it apart and clean the contacts to trouble shoot, search for "match book" posts by user name "Landtank" , it is a temporary fix but it will let you know if it is the relay.
I had thought that I had a fuel issue too.
https://forum.ih8mud.com/80-series-tech/142213-real-time-help-fuel-delivery-issue.html
It turned out to be the computer. Has your truck been welded on by chance?
Very Interesting!!!! Very similar symptoms....the only difference is mine NEVER dies! It always stays running but just at a very low ruff idle.
I don't know if my 80 has been welded on because I just bought it a few months ago. But there aren't any signs of any welding.
I feel like buying a 2nd 80 just to swap parts till I find the bad part then replace that part and sell the 2nd 80.
But I may try replacing the computer first....how much are they?:eek:
Not cheap. Thats why I changed it only after checking everything else. I found a used computer from IRBIS cheaper than I could buy a new set of wiring harnesses from Cruiserdan and gave it a shot. New computers are very pricey. You could give either of the above gentlemen a call and get the current value.
I have not yet taked time to figure what's going on in mine but it lack power when stepping on the throttle until it reachs about 3000 RPM and then it kicks hard and start to revs up :) fine and feeling like a turbo engaging on .
Dealer's mech told me that looks the pump is starting to fail :crybaby:
