Electircal switch help
South Jordan, UT
I know, I know. I struggle with the switches.
Here's what I got:
A switch that is backlit AND has an active light that is on when the switch is on.
5 pins:
A. . . . . . . B
C. . . . D. .E
A and C are always closed.
B and D are always closed.
A and E are closed when the switch is on.
C and E are closed when the switch is on.
Any ideas?
Here's my interpretation based on your info (with only one variable):
B and D are your illumination contacts-polarity shouldn't matter if it's a standard bulb inside.
E is your input
Either A or C is your output and the other is the other side of the on indicater bulb. Based on your "drawing", I would think that C is your output. If you're switching +, then A would go to ground (once again assuming it's a standard bulb inside and not an LED)
This is where it gets a little un-scientific: You can test the switch on the bench as long as you use an inline fuse rated at less than the switch (perhaps 1A). Connect E to 12V and A to ground. Turn the switch on and off quickly. If the indicater comes on, then C should be your output. If the fuse blows, or the light doesn't come on then A should be your output and C should go to ground. From what I can tell, you stand no chance of damaging the switch by testing it this way:D
Edit: if you apply power and ground to A and C with the switch on, #1 the bulb should come on and #2 E will show either + or - on a meter. If E shows + and you're applying + to C, then C is your output. If E shows - and you're applying + to C, then A is your output. Make sense? If not it may be because my coffee hasn't kicked in yet.
